Hi Christian,
i tried to do it via webapp, but that was not possible:
An unknown error with status code 504 occurred while connecting to the server, please try again later
So i checked it via univention-app command from the backend. There non of the 3 apps (core, webapp, z-push) had been listed.
Therefore i installed them again. But the webapp still shows the old number and still the same error.
When i try to execute kopano-admin, then i get the following error:
root@ucs:/home/tobias# kopano-admin
kopano-admin: /usr/lib/libkcarchiver.so.0: version `KC_8.3' not found (required by kopano-admin)
kopano-admin: /usr/lib/libkcutil.so.0: version `KC_8.2.1' not found (required by /usr/lib/libkcarchiver.so.0)
kopano-admin: /usr/lib/libkcmapi.so.0: version `KC_8.2.1' not found (required by /usr/lib/libkcarchiver.so.0)
kopano-admin: /usr/lib/libmapi.so.1: version `EC_8.2.1' not found (required by /usr/lib/libkcarchiver.so.0)
What was also strange, was some red output while installing core and webapp:
Trigger fĂĽr libapache2-mod-php5 (5.6.30+dfsg-0+deb8u1) werden verarbeitet ...
File "/usr/sbin/univention-pkgdb-scan", line 37, in <module>
univention.pkgdb.main()
File "/usr/lib/pymodules/python2.7/univention/pkgdb.py", line 616, in main
return action_scan(connection, cursor, config_registry)
File "/usr/lib/pymodules/python2.7/univention/pkgdb.py", line 527, in action_s can
scan_and_store_packages(cursor, sysname, fake_null, architecture)
File "/usr/lib/pymodules/python2.7/univention/pkgdb.py", line 453, in scan_and _store_packages
cursor.execute(delete_packages, {'sysname': sysname, })
File "/usr/lib/python2.7/dist-packages/pgdb.py", line 259, in execute
self.executemany(operation, (params,))
File "/usr/lib/python2.7/dist-packages/pgdb.py", line 291, in executemany
raise OperationalError("internal error in '%s': %s" % (sql, err))
pg.OperationalError: internal error in '
DELETE FROM packages_on_systems
WHERE sysname = 'ucs'
': SSL error: tlsv1 alert protocol version
close failed in file object destructor:
sys.excepthook is missing
lost sys.stderr
Don’t know if that is relevant…
Kind Regards,
Tobi
