Guten Morgen Herr Meybohm,
Danke für die Antwort.
Hier die Antwort zu ihren Fragen:
zu 1. Auzug aus der apache2.log
[Sun Oct 18 06:25:17 2009] [notice] Apache/2.2.3 (Univention) PHP/5.2.11-0.dotdeb.0 with Suhosin-Patch mod_ssl/2.2.3 OpenSSL/0.9.8c configured -- resuming normal operations
/usr/share/univention-directory-manager/uniconf/univention-directory-manager.py:58: SyntaxWarning: import * only allowed at module level
def main(argv):
def main(argv):
[Tue Oct 20 09:21:32 2009] [error] Internal error: pcfg_openfile() called with NULL filename
[Tue Oct 20 09:21:32 2009] [error] [client 192.168.100.5] (9)Bad file descriptor: Could not open password file: (null), referer: https://pegasus.bafoeg.studentenwerk-magdeburg.de/ucs-overview/de.html
[Tue Oct 20 09:21:32 2009] [error] [client 192.168.100.5] PAM: user 'root' - not authenticated: Error in service module, referer: https://pegasus.bafoeg.studentenwerk-magdeburg.de/ucs-overview/de.html
[Tue Oct 20 09:21:47 2009] [error] Internal error: pcfg_openfile() called with NULL filename
[Tue Oct 20 09:21:47 2009] [error] [client 192.168.100.5] (9)Bad file descriptor: Could not open password file: (null), referer: https://pegasus.bafoeg.studentenwerk-magdeburg.de/ucs-overview/de.html
[Tue Oct 20 09:21:49 2009] [error] [client 192.168.100.5] PAM: user 'Administrator' - not authenticated: Authentication failure, referer: https://pegasus.bafoeg.studentenwerk-magdeburg.de/ucs-overview/de.html
[Tue Oct 20 09:21:56 2009] [error] [client 192.168.100.5] File does not exist: /var/www/favicon.ico
[Tue Oct 20 09:21:59 2009] [error] [client 192.168.100.5] File does not exist: /var/www/favicon.ico
zu 2. es gibt nur den Administrator
zu 3. Ja, sonst kann sich der Administrator anmelden SSH / UDM…
zu 4. Nein, auch eine root Anmeldung funktioniert nicht.
Gruß
Marko
