Die Installation läuft an, bricht dann aber mit python-Fehlern ab. Hat da jemand einen Tip für mich?
univention-app install egroupware
Going to install EGroupware (20.1.20201028)
Password for Administrator:
Creating data directories for egroupware...
Registering UCR for egroupware
Marking egroupware=20.1.20201028 as installed
File: /etc/univention/service.info/services/univention-appcenter.cfg
Multifile: /etc/postgresql/9.4/main/pg_hba.conf
File: /usr/share/univention-portal/apps.json
Multifile: /etc/apache2/sites-available/000-default.conf
Multifile: /etc/apache2/sites-available/default-ssl.conf
Going to remove EGroupware (20.1.20201028)
No hostdn for egroupware found. Nothing to remove
Configuring egroupware=20.1.20201028
while scanning a simple key
in "/var/lib/univention-appcenter/apps/egroupware/compose/docker-compose.yml", line 71, column 1
could not find expected ':'
in "/var/lib/univention-appcenter/apps/egroupware/compose/docker-compose.yml", line 72, column 1
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/__init__.py", line 226, in call_with_namespace
result = self.main(namespace)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/service.py", line 82, in main
return docker.stop()
File "/usr/lib/python2.7/dist-packages/univention/appcenter/docker.py", line 663, in stop
self._setup_yml(recreate=False)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/docker.py", line 497, in _setup_yml
content = yaml.load(open(yml_file), yaml.RoundTripLoader, preserve_quotes=True)
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/main.py", line 86, in load
return loader.get_single_data()
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/constructor.py", line 54, in get_single_data
node = self.get_single_node()
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 50, in get_single_node
document = self.compose_document()
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 70, in compose_document
node = self.compose_node(None, None)
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 105, in compose_node
node = self.compose_mapping_node(anchor)
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 164, in compose_mapping_node
item_value = self.compose_node(node, item_key)
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 103, in compose_node
node = self.compose_sequence_node(anchor)
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/composer.py", line 133, in compose_sequence_node
while not self.check_event(SequenceEndEvent):
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/parser.py", line 116, in check_event
self.current_event = self.state()
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/parser.py", line 468, in parse_indentless_sequence_entry
KeyToken, ValueToken, BlockEndToken):
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/scanner.py", line 1525, in check_token
while self.need_more_tokens():
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/scanner.py", line 159, in need_more_tokens
self.stale_possible_simple_keys()
File "/usr/lib/python2.7/dist-packages/ruamel/yaml/scanner.py", line 303, in stale_possible_simple_keys
"could not find expected ':'", self.get_mark())
ScannerError: while scanning a simple key
File: /usr/share/univention-management-console/modules/apps.xml
File: /usr/share/univention-management-console/i18n/de/apps.mo
File: /etc/apt/apt.conf.d/55user_agent
egroupware=20.1.20201028: Not running, cannot check further
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/remove.py", line 56, in main
return self.do_it(args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/install_base.py", line 143, in do_it
self._do_it(app, args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_remove.py", line 51, in _do_it
super(Remove, self)._do_it(app, args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/remove.py", line 64, in _do_it
if not self._remove_app(app, args):
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_remove.py", line 60, in _remove_app
return self._remove_docker_container(app, args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_remove.py", line 68, in _remove_docker_container
Stop.call(app=app)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/__init__.py", line 220, in call
return obj.call_with_namespace(namespace)
in "<byte string>", line 71, column 1:
ox.phoenix-datentechnik.de
in "<byte string>", line 72, column 1:
odin.phoenix-datentechnik.de,465 ...
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/install.py", line 84, in main
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/docker_install.py", line 71, in _do_it
ret = super(Install, self)._do_it(app, args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/install.py", line 107, in _do_it
self._register_app(app, args)
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/register.py", line 433, in _register_app
updates.update(self._register_docker_variables(app))
File "/usr/lib/python2.7/dist-packages/univention/appcenter/actions/register.py", line 487, in _register_docker_variables
updates[app.ucr_image_key] = app.get_docker_image_name()
File "/usr/lib/python2.7/dist-packages/univention/appcenter/app.py", line 1006, in get_docker_image_name
content = yaml.load(ucr_run_filter(open(yml_file).read()), yaml.RoundTripLoader, preserve_quotes=True)
File "/usr/bin/univention-app", line 91, in <module>
main()
File "/usr/bin/univention-app", line 78, in main
ret = args.func(args)
ruamel.yaml.scanner.ScannerError: while scanning a simple key
