Join-Skript Fehler
seit einem der letzten Updates erscheint in der Management Console der Hinweis, dass einige Join-Skripte nicht ausgeführt wurden.
In der entsprechenden Übersicht steht das “97univention-s4-connector” als “ausstehend”
Wenn ich dieses neu ausführen lasse, schlägt das fehl. Im join.log steht das:
[code]RUNNING 97univention-s4-connector.inst
2016-01-11 10:54:28.036235373+01:00 (in joinscript_init)
Not updating connector/s4/ldap/host
Not updating connector/s4/ldap/base
Not updating connector/s4/ldap/ssl
Not updating connector/s4/mapping/group/language
Not updating connector/s4/ldap/protocol
Not updating connector/s4/ldap/socket
Object exists: cn=gPLink,cn=custom attributes,cn=univention,dc=domain,dc=de
Object exists: cn=WMIPolicy,cn=System,dc=domain,dc=de
Object exists: cn=SOM,cn=WMIPolicy,cn=System,dc=domain,dc=de
Object exists: cn=ldapschema,cn=univention,dc=domain,dc=de
INFO: No change of core data of object msgpo.
INFO: No change of core data of object mswmi.
Object exists: cn=udm_module,cn=univention,dc=domain,dc=de
INFO: No change of core data of object container/msgpo.
No modification: cn=msgpo,cn=ldapschema,cn=univention,dc=domain,dc=de
No modification: cn=mswmi,cn=ldapschema,cn=univention,dc=domain,dc=de
No modification: cn=container/msgpo,cn=udm_module,cn=univention,dc=domain,dc=de
Waiting for activation of the extension object msgpo: OK
Waiting for activation of the extension object mswmi: OK
Waiting for activation of the extension object container/msgpo: OK
Waiting for file /usr/share/pyshared/univention/admin/handlers/container/msgpo.py: OK
Terminating running univention-cli-server processes.
INFO: No change of core data of object settings/mswmifilter.
No modification: cn=settings/mswmifilter,cn=udm_module,cn=univention,dc=domain,dc=de
Waiting for activation of the extension object settings/mswmifilter: OK
Waiting for file /usr/share/pyshared/univention/admin/handlers/settings/mswmifilter.py: OK
INFO: No change of core data of object msprintconnectionpolicy.
INFO: No change of core data of object settings/msprintconnectionpolicy.
No modification: cn=msprintconnectionpolicy,cn=ldapschema,cn=univention,dc=domain,dc=de
No modification: cn=settings/msprintconnectionpolicy,cn=udm_module,cn=univention,dc=domain,dc=de
Waiting for activation of the extension object msprintconnectionpolicy:…
…ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-s4-connector/ldap/msprintconnectionpolicy.schema failed.
EXITCODE=1
Mo 11. Jan 10:57:34 CET 2016
univention-run-join-scripts finished[/code]
Hat jmd. ne Idee?
Vielen Dank schon mal
T0mcat
eine Suche im Bugzilla zu “msprintconnectionpolicy” findet zum Beispiel [bug]40300[/bug], der ist allerdings im Kontext von UCS@School.
Viele Grüße,
Dirk Ahrnke
