Join into an existing MS AD Domain failed
I want to setup a UCS-Domain and sync it with an existing MS AD-Domain.
During the installation of the first UCS-Server I chose the option ‘Join into an existing Microsoft Active Directory domain’
After the installation process some errors/warning occurred.
I decided to go on and to deal with the problem later.
Now i have discovered that one join-script did not succeed.
When i rerun the join-script i get this error:
root@ucs-master:~# univention-run-join-scripts --ask-pass
copyright © 2001-2020 Univention GmbH, Germany
Enter DC Master Account : myaduser
Enter DC Master Password:
Search LDAP binddn: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,keyboard-interactive).
  • Running join scripts failed! *
  • Message: binddn for user myaduser not found
myaduser is a MS AD-User with admin permissions.
Its DN is
CN=My ADUser,OU=Location1,OU=AD-Accounts,DC=sub,DC=example,DC=org
Maybe this uncommon DN is the problem?
Any help is welcome
Thank you
Ritchi
UCS version is 4.4-5 errata686
