hi everyone, I would like to test a new install of ucs-5, but I definitively need NextCloud.
Is ti possible to install from docker rep ? Or should I stick to Univention repo ?
thanks for your lights.
Use the default. The UCS Appcenter.
will it be backward compatible ?
Ähm… In what way? .
I Guess when you said “use the Ucs appcenter” you mean ucs-4 appcenter.
because I already use the default appcenter but in uce-5 there is not Nexcloud.
So if it is the Appcenter for Ucs-4, will it be backward compatible with UCE-5 ? I’m not sure.
regards.
Oh, hmm… ok. Yeah, i never tested UCS5, so sorry yes i can’t help you with. Strange, no Nextcloud in UCS5, this is one from the main apps…
this is what I have as repository.
