Is it possible to get rid of LVM on UCS?
Hi guys,
I’m running UCS as a VM on proxmox and I did run into some issues with /boot getting too small. So my first thought was, why not using the good ol’ system rescue CD and just use good 'ol gparted to sort things out.
Sadly I discovered that UCS runs LVM which I couldn’t move.As swap is also on the LVM, I’m pretty much out of ‘sane options’.
My ideas range from adding another disk as /boot up to just making a tarball of the rootfs and unpacking that onto a new disk…
Mastodon
