I’m having problem regarding my next cloud installation due to the installation was interrupted by power surge. When I’m try to reinstall the server I’m having this error.
Creating data directories for nextcloud...
Copying /var/cache/univention-appcenter/appcenter.software-univention.de/4.1/nextcloud_20180807173304.schema
Registering UCR for nextcloud
Marking 4.1/nextcloud=13.0.5-0 as installed
File: /etc/univention/service.info/services/univention-appcenter.cfg
File: /usr/share/univention-portal/apps.json
Multifile: /etc/postgresql/9.6/main/pg_hba.conf
Setting ports for apache proxy
Multifile: /etc/apache2/sites-available/000-default.conf
Multifile: /etc/apache2/sites-available/default-ssl.conf
Creating /etc/init.d/docker-app-nextcloud
Adding localhost to LDAP object
Setting overview variables
Module: create_portal_entries
Reloading apache2 configuration (via systemctl): apache2.service.
univention-postgresql was already set to manually installed.
4.1/nextcloud=13.0.5-0 already has its database
Registering schema /usr/share/univention-appcenter/apps/nextcloud/nextcloud.schema
INFO: No change of core data of object nextcloud.
No modification: cn=nextcloud,cn=ldapschema,cn=univention,dc=holyspirit-manila,dc=intranet
WARNING: cannot append nextcloud to appidentifier, value exists
Waiting for activation of the extension object nextcloud:....................
ERROR: Master did not mark the extension object active within 180 seconds.
Registering schema file /usr/share/univention-appcenter/apps/nextcloud/nextcloud.schema failed
Thank You.
