UCS 4.2-1 errata52
During install, and later also I see the following in the syslog:
loading configuration from ‘/etc/bind/named.conf.proxy’
/etc/bind/named.conf.proxy:14: expected IP match list element near ‘;’
exiting (due to fatal error)
If I add ANY to that config it errors out on the load files later on in the file.
and I think i found the error.
05univention-bind.inst
failed nameserver: Value may not contain other than numbers, letters and dots!
my ucs server name is directory.11.apo
Traceback is /usr/share/univention-admin-tools/univention-dnsedit, line 403 in module main
looks like Problem mit DNS Zonen WebInterface became worse.
