Hallo!
ich habe das Problem, dass die Installation von OpenProject aus dem Appcenter mit folgender Meldung abgebrochen wird:
Beim Versuch der Umsetzung kam es zu Fehlern bei openproject
Diese Fehlermeldungen kommen vom Server. Weitere Informationen können in der Logdatei des Systems enthalten sein: /var/log/univention/appcenter.log
Setup script failed!
In der appcenter.log findet sich folgendes
18620 actions.install 23-02-15 14:58:02 [ INFO]: Executing interface setup for openproject
18620 actions.install 23-02-15 14:58:02 [ INFO]: Copying App Center's setup to container's /usr/share/univention-docker-container-mode/setup_custom
18620 actions.install.container.ffe0 23-02-15 14:58:02 [ DEBUG]: Using container.ffe0 for container ffe07830b51b142d3a39e69f97acfb49f4dff4066fdb5af9b12049bd884a53c5
18620 actions.install.container.ffe0 23-02-15 14:58:02 [ DEBUG]: Calling docker exec -u root ffe07830b51b142d3a39e69f97acfb49f4dff4066fdb5af9b12049bd884a53c5 /usr/share/univention-docker-co
ntainer-mode/setup_custom --username Administrator --password-file /var/univention/tmp/tmpgg1xdfo6 --error-file /var/univention/tmp/tmpqwb0qs7k --app openproject --app-version 12.4.2
18620 actions.install.container.ffe0 23-02-15 14:58:20 [ WARNING]: /app/config/constants/settings/definition.rb:305:in `find_env_var_override': Using unprefixed environment variables is depre
cated. Please use OPENPROJECT_RAILS_CACHE_STORE instead of RAILS_CACHE_STORE (StructuredWarnings::StandardWarning)
18620 actions.install.container.ffe0 23-02-15 14:58:29 [ WARNING]: /app/vendor/bundle/ruby/3.1.0/gems/activerecord-7.0.4/lib/active_record/railtie.rb:154:in `block (3 levels) in <class:Railti
e>': Ignoring /app/db/schema_cache.yml because it has expired. The current schema version is 20221018160449, but the one in the schema cache file is 20230105134940. (StructuredWarnings::Standard
Warning)
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: /app/lib/tasks/database.rake:88:in `rescue in block (3 levels) in <top (required)>':
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: ---------------------------------------------------
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: DATABASE DEPRECATION WARNING
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: The next major release of OpenProject (v12) will require PostgreSQL 13 or later.
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: You can anticipate this upgrade by updating your database installation by following the guide at https://www.openproject.org
/docs/installation-and-operations/misc/migration-to-postgresql13/
18620 actions.install.container.ffe0 23-02-15 14:58:30 [ WARNING]: (StructuredWarnings::StandardWarning)
18620 packages 23-02-15 14:58:42 [ DEBUG]: Releasing LOCK
18620 actions.install 23-02-15 14:58:42 [CRITICAL]: Setup script failed!
Hat jemand eine Idee, woran das liegen kann?
Danke im Voraus!
