Installation Imapsync auf UCS
wir wollen gerne imapsync installieren. Die Installationsanweisung ist da sehr einfach:
#!/bin/cat
# $Id: INSTALL.Debian.txt,v 1.7 2016/06/22 19:58:32 gilles Exp gilles $
There is one section for Debian 7 and one for Debian 6.
= Installing imapsync on Debian 7 Wheezy =
Here are the two commands to install imapsync dependencies.
You need root priviledge to run them.
The first command installs standard Debian packages:
  apt-get install
libauthen-ntlm-perl
libcrypt-ssleay-perl
libdigest-hmac-perl
libfile-copy-recursive-perl
libio-compress-perl
libio-socket-inet6-perl
libio-socket-ssl-perl
libio-tee-perl
libmodule-scandeps-perl
libnet-ssleay-perl
libpar-packer-perl
libreadonly-perl
libterm-readkey-perl
libtest-pod-perl
libtest-simple-perl
libunicode-string-perl
liburi-perl
cpanminus
The second command installs "manually" the Perl module Data::Uniqid
because Debian hasn't made it available via a package yet.
It also  install manually Perl module Mail::IMAPClient because
it is good to be up to date:
  cpanm Data::Uniqid Mail::IMAPClient
After installing the dependencies, imapsync should be working.
You don't have to be root to test and use imapsync.
Take the compressed tarball called imapsync-1.xxx.tgz
where 1.xxx is the version number.
Untar the tarball where you want:
  cd
  tar xzvf  imapsync-1.xxx.tgz
Go into the directory imapsync-1.xxx
  cd imapsync-1.xxx
A dependencies test that shows also the basic example:
  ./imapsync
A live test showing imapsync job:
  ./imapsync --testslive
Now the install command (need root priviledges again):
  cp imapsync /usr/bin/
That's finished for the installation part.
You can use imapsync.
Now go to read http://imapsync.lamiral.info/#doc
start with the tutorial.
= Installing imapsync on Debian 6 Squeeze =
  apt-get install
libdigest-hmac-perl
libio-compress-perl
libio-tee-perl
libnet-ssleay-perl
libpar-packer-perl
libreadonly-perl
libtest-pod-perl
libtest-simple-perl
liburi-perl
  perl -MCPAN -e "install Data::Uniqid"
  perl -MCPAN -e "install Authen::NTLM"
  perl -MCPAN -e "install Mail::IMAPClient"
The Perl module Mail::IMAPClient is good to be recent
and installed manually.
  cd
  cd imapsync-1.xxx
  ./imapsync
Leider kriegen wir die dependencies aber schon nicht sauber drauf:
apt-get install
> libauthen-ntlm-perl
> libdigest-hmac-perl
> libio-compress-perl
> libio-tee-perl
> libnet-ssleay-perl
> libpar-packer-perl
> libreadonly-perl
> libtest-pod-perl
> libtest-simple-perl
> liburi-perl
> cpanminus
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Hinweis: »perl« wird an Stelle von »libio-compress-perl« gewählt.
Hinweis: »perl-modules« wird an Stelle von »libtest-simple-perl« gewählt.
Paket libcrypt-ssleay-perl ist nicht verfügbar, wird aber von einem anderen Paket
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
Paket libauthen-ntlm-perl ist nicht verfügbar, wird aber von einem anderen Paket
E: Für Paket »libauthen-ntlm-perl« existiert kein Installationskandidat.
E: Für Paket »libcrypt-ssleay-perl« existiert kein Installationskandidat.
E: Paket libio-tee-perl kann nicht gefunden werden.
E: Paket libmodule-scandeps-perl kann nicht gefunden werden.
E: Paket libpar-packer-perl kann nicht gefunden werden.
E: Paket libtest-pod-perl kann nicht gefunden werden.
E: Paket cpanminus kann nicht gefunden werden.
root@ucs:/usr/local/src/imapsync-1.727# ./imapsync
Can't locate IO/Tee.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at ./imapsync line 717.
BEGIN failed--compilation aborted at ./imapsync line 717.
root@ucs:/usr/local/src/imapsync-1.727# ./imapsync --testslive
Der Aufruf des programms selber scheitert auch:
./imapsync Can't locate IO/Tee.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at ./imapsync line 717. BEGIN failed--compilation aborted at ./imapsync line 717.
Hat jemand eine Idee, wie es gehen kann?
Danke
Sascha
ucr set repository/online/unmaintained='yes'
aptitude update
Ups…das war einfach…:slight_smile:
Klappt hervorragend,
Danke
Sascha
Freut mich, daß es geklappt hat. Anschließend sollte man es wieder deaktivieren:
ucr set repository/online/unmaintained='no'
na klar, logisch!
danke nochmal
Sascha
