Is the DC-Master server also mentioned in /etc/stunnel/univention_saml.conf of the DC Backup?
Maybe after ucr commit /etc/stunnel/univention_saml.conf && invoke-rc.d univention-saml restart
yes it is
root@p-ucs-backup:~# cat /etc/stunnel/univention_saml.conf
; Warning: This file is auto-generated and might be overwritten by
; univention-config-registry.
; Please edit the following file(s) instead:
; Warnung: Diese Datei wurde automatisch generiert und kann durch
; univention-config-registry überschrieben werden.
; Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
; /etc/univention/templates/files/etc/stunnel/univention_saml.conf
pid = /var/run/univention-saml/stunnel4.pid
cert = /etc/simplesamlphp/p-ucs-master.xxx.lcl-idp-certificate.crt
key = /etc/simplesamlphp/p-ucs-master.xxx.lcl-idp-certificate.key
setuid = samlcgi
CAfile = /etc/univention/ssl/ucsCA/CAcert.pem
options = NO_SSLv2
service = univention-saml-stunnel
debug = 4
[memcached]
accept = 11212
connect = /var/run/univention-saml/memcached.socket
verify = 2
checkHost = univention.xxx.nl
[p-ucs-master.finalist.lcl]
client = yes
accept = /var/run/univention-saml/p-ucs-master.xxx.lcl.socket
connect = p-ucs-master.xxx.lcl:11212
verify = 2
I can’t explain then why the file /var/run/univention-saml/p-ucs-master.xxx.lcl.socket doesn’t exists.
Are there any error messages when you do:
invoke-rc.d stunnel4 restart
cat /var/log/stunnel4/stunnel.log
ls -l /var/run/univention-saml/p-ucs-master.xxx.lcl.socket
ps aufx | grep stunnel
I made some progress.
chown samlcgi:root /var/run/univention-saml/p-ucs-backup.xxx.lcl.socket
I have 2 sockets now.
But the connection with the other server is dropped (socket was unexpectedly closed) because of an SSL isssue
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[main]: Service [p-ucs-backup.xxx.lcl] accepted (FD=3) from unnamed socket
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Service [p-ucs-backup.xxx.lcl] started
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Option TCP_NODELAY not supported on local socket
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG5[2]: Service [p-ucs-backup.xxx.lcl] accepted connection from unnamed socket
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG6[2]: failover: round-robin
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG6[2]: s_connect: connecting 10.120.10.9:11212
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: s_connect: s_poll_wait 10.120.10.9:11212: waiting 10 seconds
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG5[2]: s_connect: connected 10.120.10.9:11212
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG5[2]: Service [p-ucs-backup.xxx.lcl] connected remote server from 192.168.0.154:48491
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Remote socket (FD=9) initialized
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG6[2]: SNI: sending servername: p-ucs-backup.xxx.lcl
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: SSL state (connect): before/connect initialization
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: SSL state (connect): SSLv2/v3 write client hello A
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: SSL state (connect): unknown state
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Verification started at depth=0: C=US, ST=Unknown, L=Unknown, O=Unknown, CN=p-ucs-master.xxx.lcl
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG4[2]: CERT: Pre-verification error: self signed certificate
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG4[2]: Rejected by CERT at depth=0: C=US, ST=Unknown, L=Unknown, O=Unknown, CN=p-ucs-master.xxx.lcl
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: SSL alert (write): fatal: unknown CA
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG3[2]: SSL_connect: 14090086: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG5[2]: Connection reset: 0 byte(s) sent to SSL, 0 byte(s) sent to socket
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Deallocating application specific data for addr index
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Remote socket (FD=9) closed
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Local socket (FD=3) closed
Feb 9 12:16:51 p-ucs-master univention-saml-stunnel: LOG7[2]: Service [p-ucs-backup.xxx.lcl] finished (0 left)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] SimpleSAML_Error_Exception: Error 8 - MemcachePool::get(): Server unix:///var/run/univention-saml/p-ucs-backup.xxx.lcl.socket (tcp 0, udp 0) failed with: Read failed (socket was unexpectedly closed) (0)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] Backtrace:
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 12 /usr/share/simplesamlphp/www/_include.php:70 (SimpleSAML_error_handler)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 11 [builtin] (MemcachePool::get)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 10 /usr/share/simplesamlphp/lib/SimpleSAML/Memcache.php:41 (SimpleSAML_Memcache::get)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 9 /usr/share/simplesamlphp/lib/SimpleSAML/Store/Memcache.php:28 (SimpleSAML_Store_Memcache::get)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 8 /usr/share/simplesamlphp/lib/SimpleSAML/SessionHandlerStore.php:38 (SimpleSAML_SessionHandlerStore::loadSession)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 7 /usr/share/simplesamlphp/lib/SimpleSAML/Session.php:1104 (SimpleSAML_Session::getSession)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 6 /usr/share/simplesamlphp/lib/SimpleSAML/Session.php:221 (SimpleSAML_Session::getSessionFromRequest)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 5 /usr/share/simplesamlphp/lib/SimpleSAML/Logger.php:306 (SimpleSAML_Logger::getTrackId)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 4 /usr/share/simplesamlphp/lib/SimpleSAML/Logger.php:272 (SimpleSAML_Logger::log)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 3 /usr/share/simplesamlphp/lib/SimpleSAML/Logger.php:162 (SimpleSAML_Logger::debug)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 2 /usr/share/simplesamlphp/lib/SimpleSAML/Auth/State.php:211 (SimpleSAML_Auth_State::loadState)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 1 /usr/share/simplesamlphp/modules/core/www/loginuserpass.php:24 (require)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 3 [NA] 0 /usr/share/simplesamlphp/www/module.php:134 (N/A)
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 7 [0a75c86954] Loading state: '_3b65c48cdd87bf918afe99098f53fdfd20f723bc38:https://univention.xxx.nl/simplesamlphp/saml2/idp/SSOService.php?spentityid=https.xxx.nl&cookieTime=1455013969&RelayState=ss'
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 7 [0a75c86954] Template: Reading [/usr/share/simplesamlphp/modules/univentiontheme/dictionaries/univention]
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 7 [0a75c86954] Template: Reading [/usr/share/simplesamlphp/dictionaries/login]
Feb 9 12:16:51 p-ucs-master simplesamlphp[26510]: 7 [0a75c86954] Template: Reading [/usr/share/simplesamlphp/modules/univentiontheme/dictionaries/login]
Please compare the files /etc/simplesamlphp/p-ucs-master.xxx.lcl-idp-certificate.crt (and the private key) on all servers. They must be the same.
The same goes for /etc/univention/ssl/ucs-sso.$domainname/cert.pem.
The /etc/simplesamlphp/p-ucs-master.xxx.lcl-idp-certificate.crt must be readable by the “samlcgi” user.
Does the memcached socket exists? →/var/run/univention-saml/memcached.socket
Is it owned and writeable by “samlcgi” user?
Does the memcached process run?
Because of issue New SAML metadata after upgrading to UCS 4.1 I replaced the new IdP crt/key files by the ones used in UCS 4.0
This way I prevented that I needed to change the metadata on all service providers.
I compared the two IdP crt-files. The new one contains much more information. I guess that is the problem for Stunnel.
The other issue with re-using the UCS 4.0 files is that SSO for UMC doesn’t work.
So I think that the best is to use the new crt-file and update all service providers with the new metadata.
