Problem: Delete "deleted objects" in Samba
Sympthom
You tried to delete an already deleted object in samba. Perhaps you followed this article
and you stumble across this error message with this delete command.
ldbdel --cross-ncs --show-deleted --relax -r -H /var/lib/samba/private/sam.ldb 'cn=christina\0ADEL:891c4c0d-ff30-4acd-9dbb-c24ed355fc0d,CN=Deleted Objects,DC=schein,DC=me' delete of 'cn=christina\0ADEL:891c4c0d-ff30-4acd-9dbb-c24ed355fc0d,CN=Deleted Objects,DC=schein,DC=me' failed - (Operations error) (null)
What could go wrong here? It should be possible to delete this object.
The error message is quite misleading. The parameter -r for recursive cannot be combined with the parameter --relax
ldbdel --cross-ncs --show-deleted --relax -H /var/lib/samba/private/sam.ldb 'cn=cluwitsch2\0ADEL:891c4c0d-ff30-4acd-9dbb-c24ed355fc0d,CN=Deleted Objects,DC=schein,DC=me' Deleted 1 record
Important additional note:
If the parameter --relax is necessary:
Refusing to delete xxx This check is to prevent corruption of
the replicated state
than the delection has to be done on each drs replication partner in the domain, otherwise the drs replication gets stuck!
Mastodon
