How To: Configure Attachment Limits for OX Drive
Howto
Configure attachment limits for the OX- Drive app.
Attachments for Emails and Calendar
Default value is 10MB. Set the desired value through the following UCR-variable. Value has to be given in Bytes. To set it to 100MB:
root@ucs:~# ucr set ox/cfg/attachment.properties/MAX_UPLOAD_SIZE=104857600
Attachments for OX-Drive Uploads
Default value is 10MB. Set the desired value through the following UCR-variable. Value has to be given in Bytes. To set it to 500MB:
root@ucs:~# ucr get ox/cfg/infostore.properties/MAX_UPLOAD_SIZE=524288000
Note: For calculation you might use this site.
