Is there a straight forward way to add bulk users into UCS?
There is no simple way and in the forum, there is always a mention of one or other method but not a simple way.
Any pointer to the correct URL would be appreciated
Hey,
Univention comes with a command-line utility called “Univention Directory Manager”, its binary being udm. With it you can automate creation, deletion or modification of all objects in the LDAP server — including groups and users.
Normally I have a list of users and groups to create somewhere, e.g. in a CSV file. What I usually do is whip up a Perl script that reads such a file and creates the appropriate commands.
Here’s an example for creating a single user:
udm users/user create --ignore_exists \
--superordinate cn=users,dc=internal,dc=mydomain,dc=de \
--set overridePWHistory=1 \
--set overridePWLength=1 \
--set username=jdoe \
--set uidNumber=12345 \
--set firstname=Jane \
--set lastname=Doe \
--set unixhome=/home/jdoe \
--set shell=/bin/bash \
--set password=ThisIsTheNewPasswordInPlaintext \
--set 'primaryGroup=cn=Domain Users,cn=groups,dc=internal,dc=mydomain,dc=de' \
--set e-mail=jdoe@mydomain.de \
--set PasswordRecoveryEmail=jdoe@mydomain.de
You can learn about the Univention Directory Manager in the admin docs.
Kind regards,
mosu
Hi Moritz,
We are migrating a database of users including encrypted passwords in bulk. Can we use this command to recreate the users on a new installation. Will this command also interact with OX Mail /opt/open-xchange/sbin/createuser to manage this users? or it has to be run on separate instance?
Rgds,
Rolando
