How to activate Nubus after installing UCS, what are the steps
Hi there,
You need to read a bit about the UCS and its features.
You’ve installed UCS which is a “domain controller”, NUBUS is identity manager for K8s.
Thanks! So Nubus is a seperate component installed on Kubernetes?
Yes
Nubus provides the identity part in K8s cluster. You have installed UCS so you can achieve the same for a ‘normal’ network/system
