Horde problem - How to debug?
I have a problem with Horde working on my memberserver. Login page load correctly but when I try to log in page just refresh and returns to login page. All happens when I set UCS variable samba/share/home to no (User Windows home path folder as share on memberserver - How to disable?).
Please can you give me a hint where to check logs or how to resolve this issue?
Thanks in advance.
That does not sound reasonable, as setting that variable should only change smb.conf. Nevertheless, you can enter the horde container on the command line with
# univention-app shell horde
and check
ls /var/log/apache2/
ls /var/log/horde/
