I just installed Wekan last week using the VirtualBox ova. It imported, I started it, I entered the email requested for the activation key (same email I’m using for this forum), and it finished the setup. It told me to open a browser, go to 10.0.0.144 and upload the key which should come in an email.
I go to my Gmail, and I see the Onboarding email message from Univention, but there is no key file attached.
I found a help contact email for Univention and sent a request for help there last Friday.
I reinstalled Wekan again, and this time tried to login at the root console using the password I set for root and Administrator. Guess what? Neither of them work.
Anyone got an explanation for that? I follow the steps exactly as required and login still doesn’t work. I can’t login using the Management Console because I still don’t have a license key.
I also contacted Wekan support and all they could suggest is to install it using the Snap version. I did that, but I don’t like snap apps, and I would like to get the VB version working, but that depends on getting a license key from Univention. Does Univention still support the Wekan app?
How can I get a license key?
Thanks in advance for any assistance.
