I installed curlftpfs in a container that is running CentOS 6.9. When I try to mount an FTP host I receive this error:
fuse: failed to open /dev/fuse: Operation not permitted
I read in a Docker forum a few things about it where adding the following to the container connection would help:
–privileged --device=/dev/fuse
They do this with the command “docker run” but I don’t know how to use this with the “univention-app” command.
I basically need to get into my app’s shell and I have tried stuff like this:
univention-app shell -it filewave --privileged --device /dev/fuse
but this returns an rcp error:
rpc error: code = 2 desc = containerd: container not started
Any help will be appreciated.
Thank you,
Mauricio.
