Versuche Freeradius zu installieren auf UCS 2.2. Kriege folgende Fehlermeldung wegen ein Konflikt mit univention-smbencrypt
root@ucs-master:/usr/bin# apt-get install freeradius
Reading package lists... Done
Building dependency tree... Done
Suggested packages:
freeradius-mysql freeradius-krb5
The following NEW packages will be installed:
freeradius
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0B/732kB of archives.
After unpacking 2761kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
freeradius
Authentication warning overridden.
(Reading database ... 81016 files and directories currently installed.)
Unpacking freeradius (from .../freeradius_1.1.3-3.31.200710190554_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/freeradius_1.1.3-3.31.200710190554_i386.deb (--unpack):
trying to overwrite `/usr/bin/smbencrypt', which is also in package univention-smbencrypt
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
