Freeradius in docker container
Hi! I want use docker containerunivention/ucs-slave-amd64 as slave for my master UCS. But I use freeradius on my master
and I want replication they on my slave. But univention/ucs-slave-amd64 doesn’t have free radius. I tried install radius by apt install and repeated univention-join script. It didn’t help. Maybe I have opportunity for using docker as I want?
Hey,
according to the Radius app’s meta data it should be available for installation on DC Slaves. What exactly do you mean by “But univention/ucs-slave-amd64 doesn’t have free radius.”?
I tried install radius by apt install…
If you only install the freeradius package, you’ll only get the standard Debian FreeRadius application. The integration into UCS is part of another package; and installing the “Radius” app from the App Center will install both the freeradius package as well as the UCS integration package.
m.
