root@ucs002254:~# ls -l /dev/sd*
brw-rw---T 1 root disk 8, 0 Okt 19 16:48 /dev/sda
brw-rw---T 1 root disk 8, 1 Okt 19 16:48 /dev/sda1
brw-rw---T 1 root disk 8, 2 Okt 19 16:48 /dev/sda2
brw-rw---T 1 root disk 8, 3 Okt 19 16:48 /dev/sda3
root@ucs002254:~#
root@ucs002254:~# mount /dev/sda2 /mnt
root@ucs002254:~# ls -l /mnt
insgesamt 39542
-rw-r--r-- 1 root root 318 Jun 7 17:46 boot.msg
-rw-r--r-- 1 root root 167319 Apr 15 2016 config-4.1.0-ucs190-amd64
drwxr-xr-x 2 root root 1024 Jun 7 17:26 efi
drwxr-xr-x 5 root root 1024 Jun 7 17:46 grub
-rw-r--r-- 1 root root 28195098 Jun 7 17:46 initrd.img-4.1.0-ucs190-amd64
drwxr-xr-x 2 root root 12288 Jun 7 17:26 lost+found
-rw-r--r-- 1 root root 176764 Feb 27 2015 memtest86+.bin
-rw-r--r-- 1 root root 178944 Feb 27 2015 memtest86+_multiboot.bin
-rw-r--r-- 1 root root 2851820 Apr 15 2016 System.map-4.1.0-ucs190-amd64
-rw-r--r-- 1 root root 4367536 Apr 15 2016 vmlinuz-4.1.0-ucs190-amd64
-rw-r--r-- 1 root root 4371456 Apr 27 19:01 vmlinuz-4.1.0-ucs190-amd64.efi.signed
root@ucs002254:~# umount /mnt
[code]root@ucs002254:~# cat /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/dev/mapper/vg_ucs-root / ext4 errors=remount-ro,user_xattr 0 1
/boot was on /dev/sda2 during installation
UUID=1deb8589-2aba-4904-9d12-1c7e79f4067a /boot ext2 defaults,user_xattr 0 2
/boot/efi was on /dev/sda1 during installation
UUID=64AB-D023 /boot/efi vfat defaults 0 1
/dev/mapper/vg_ucs-swap_1 none swap sw 0 0
/dev/sdb1 /media/usb0 auto rw,user,noauto 0 0
root@ucs002254:~#
[/code]
Wow, ich denke das ist das Problem. Du hast recht, das wird “falsch” gemounted
Was kann ich dagegen jetzt tun?
