Error installing univention-mtpolicyd
Hi all,
I have tried to install the package univention-Mtpolicyd, but it ends in error:
You cannot continue
The following packages will be installed or upgraded:
geoip-database
This operation causes problems in the following packages that cannot be resolved:
In the logs: management-console-module-appcenter.log
Further information regarding this error:
Error: Unable to correct problems, you have held broken packages.
23.02.19 19:45:41.034  MAIN        ( WARN    ) : Shutting down all open connections
23.02.19 21:56:12.016  DEBUG_INIT
23.02.19 21:56:12.413  MODULE      ( PROCESS ) : Loading python module.
23.02.19 21:56:12.480  MODULE      ( PROCESS ) : Imported python module.
23.02.19 21:56:12.480  MODULE      ( PROCESS ) : Module instance created.
23.02.19 21:56:12.480  MODULE      ( PROCESS ) : Module socket initialized.
23.02.19 21:56:12.512  MODULE      ( PROCESS ) : Setting user LDAP DN 'uid=Administrator,cn=users,dc=vacancy-rewards,dc=intranet'
23.02.19 21:56:12.512  MODULE      ( PROCESS ) : Setting auth type to None
23.02.19 21:56:12.512  MODULE      ( PROCESS ) : Initializing module.
23.02.19 21:59:53.170  MODULE      ( ERROR   ) : Failed connection: ECONNRESET
23.02.19 23:02:01.629  DEBUG_INIT
23.02.19 23:02:02.000  MODULE      ( PROCESS ) : Loading python module.
23.02.19 23:02:02.070  MODULE      ( PROCESS ) : Imported python module.
23.02.19 23:02:02.070  MODULE      ( PROCESS ) : Module instance created.
23.02.19 23:02:02.070  MODULE      ( PROCESS ) : Module socket initialized.
23.02.19 23:02:02.114  MODULE      ( PROCESS ) : Setting user LDAP DN 'uid=Administrator,cn=users,dc=vacancy-rewards,dc=intranet'
23.02.19 23:02:02.114  MODULE      ( PROCESS ) : Setting auth type to None
23.02.19 23:02:02.114  MODULE      ( PROCESS ) : Initializing module.
23.02.19 23:09:06.320  MODULE      ( WARN    ) :
Any help is welcome
Thank you.
Best regards,
have you tried this?
KNEBB
