During the pre-update script, I have the error :
The system can not be updated to UCS 5.0 due to the following reasons:
python_ucr_template_compatibility:
The following UCR templates are not compatible with Python 3:
/etc/univention/templates/files/etc/ldap/slapd.conf.d/11univention-ldap-usercert_schema (package: univention-ldap-usercert)
See <https://help.univention.com/t/17948> for information on how to proceed with each template.
old_packages:
WARNING: The following packages from UCS-4 are still installed, which are no longer supported with UCS-5:
univention-kdm
univention-x-core
univention-dansguardian
Use "univention-remove --purge" with the packages as following arguments to remove them
minimum_ucs_version_of_all_systems_in_domain:
The following extensions are incompatible with UCS 5.0:
cn=univention-openvpn,cn=udm_hook,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=univention-openvpn-schema,cn=udm_syntax,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=63openvpn-sitetosite,cn=ldapacl,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=WindowsCertificateHook,cn=udm_hook,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=SimpleAuthCertificateHook,cn=udm_hook,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=guacamole,cn=udm_syntax,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
cn=guacamole/config,cn=udm_module,cn=univention,dc=dmp,dc=intranet: [unspecified..unspecified)
Error: Update aborted by pre-update script of release 5.0-0
Can I safely remove the univention-kdm, univention-x-core, univention-dansguardian (I have squid installed) ?
and for the extension, openvpn, guacamole have been remove for more than 1 year on the server
Vincent
