Entry added in default-ssl.conf - good idea?
hi,
I’ve set up a member server with Confluence. I want to use this via the reverse proxy of the UCS server and have added 2 lines in the default-ssl.conf and everyting works fine.
ProxyPass /confluence http://192.168.1.5:8090/confluence retry=0
ProxyPassReverse /confluence http://192.168.1.5:8090/confluence
My question is whether this entry will survive an update of the system or whether it would be better to outsource this to my own conf?
tia,
hpz
you should definitely put it into your own conf. the header of the file you specified already said that your changes will be overwritten:
#          univention-config-registry.
#          Please edit the following file(s) instead:
#          univention-config-registry ueberschrieben werden.
#          Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/00start
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/10hsts
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/10univention-appcenter
#       /etc/univention/templates/files/etc/apache2/sites-available/ssl.d/99end
If you want to keep it minimal you could post your two liner as a yourname.conf file into /etc/apache2/ucs-sites.conf.d/
