DynDNS is driving me crazy
Hey there! I’ve set up a UCS on my server and as long as it is accessed locally, everything works, but if i try to contact it fron the outside to its assigned dydns, it loads the site for half an eternity and then times out. Every port that ucs needs has been forwarded and the IP address assigned to the dyndns hostname is also correct. i’m actually at my end i dont know what to do anymore. Thanks in advance!
Hi nikithd
Have you try to connect directly to the management console?
https://your-dyndns-entry.tld/univention/management
I once had to struggle with strange redirect problems when I wanted to connect directly to the site.
Greez
AlteSocke
Mastodon
