1.1.0-1 installed. Upgrade to 1.2.0-1 available
Dudle cannot be updated. The application is either not installed or no newer version is available.
4.2-4 (cant upgrade cause its an client)
Could you post the /var/log/univention/appcenter.log file? Maybe this gives us a clue about what is going on.
Best regards,
Felix
War nicht viel drin zu finden am 09.
32169 actions.upgrade-search 18-07-08 14:07:55 [ DEBUG]: Checking 4.1/dudle=1.1.0-1
32169 actions.upgrade-search 18-07-08 14:07:55 [ INFO]: Executing interface update_available for dudle
16149 actions.register 18-07-08 15:02:56 [ INFO]: Registering UCR for dudle
16149 actions.register 18-07-08 15:02:56 [ INFO]: Marking 4.1/dudle=1.1.0-1 as installed
16149 actions.register 18-07-08 15:02:56 [ INFO]: Creating /etc/init.d/docker-app-dudle
16149 actions.register 18-07-08 15:02:56 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-dudle defaults 41 14
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Changed: set(['dudle'])
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/description' -> 'Schedule events and execute polls very easy'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/label/de' -> u'Dudle - Termine & Umfragen'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/description/de' -> 'Terminfindung und Abstimmungen einfach durchf\xc3\xbchren'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/port_http' -> '80'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/link' -> '/dudle'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/icon' -> '/univention/js/dijit/themes/umc/icons/scalable/apps-dudle_20160201.svg'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/port_https' -> '443'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Matched 'ucs/web/overview/entries/service/dudle/label' -> u'Dudle - Termine & Umfragen'
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Processing cn=dudle,cn=portal,cn=univention,dc=xxx,dc=xxx
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Attrs: {'category': 'service', 'displayName': [('de_DE', u'Dudle - Termine & Umfragen'), ('en_US', u'Dudle - Termine & Umfragen')], 'name': 'dudle', 'description': [('en_US', 'Schedule events and execute polls very easy'), ('de_DE', 'Terminfindung und Abstimmungen einfach durchf\xc3\xbchren')], 'icon': '...'}
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Links: ['https://10.0.10.76/dudle', 'https://ucs.rent24.com/dudle', 'http://ucs.rent24.com/dudle', 'http://10.0.10.76/dudle']
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: Existing links: ['https://10.0.10.76/dudle', 'https://ucs.rent24.com/dudle', 'http://ucs.rent24.com/dudle', 'http://10.0.10.76/dudle']
16149 portalentries 18-07-08 15:02:57 [ DEBUG]: New links: ['https://10.0.10.76/dudle', 'https://ucs.rent24.com/dudle', 'http://ucs.rent24.com/dudle', 'http://10.0.10.76/dudle']
10459 actions.register 18-07-08 15:36:36 [ INFO]: Registering UCR for dudle
10459 actions.register 18-07-08 15:36:36 [ INFO]: Marking 4.1/dudle=1.1.0-1 as installed
10459 actions.register 18-07-08 15:36:36 [ INFO]: Creating /etc/init.d/docker-app-dudle
10459 actions.register 18-07-08 15:36:36 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-dudle defaults 41 14
5529 actions.register 18-07-08 15:40:54 [ DEBUG]: Calling /usr/sbin/update-rc.d docker-app-dudle remove
5529 portalentries 18-07-08 15:41:06 [ DEBUG]: Changed: set(['dudle'])
5529 portalentries 18-07-08 15:41:06 [ DEBUG]: Processing cn=dudle,cn=portal,cn=univention,dc=rent24,dc=com
5529 portalentries 18-07-08 15:41:07 [ DEBUG]: Existing links: ['https://10.0.10.76/dudle', 'https://ucs.rent24.com/dudle', 'http://ucs.rent24.com/dudle', 'http://10.0.10.76/dudle']
5529 portalentries 18-07-08 15:41:07 [ DEBUG]: Changed: set(['dudle'])
5529 portalentries 18-07-08 15:41:07 [ DEBUG]: Processing cn=dudle,cn=portal,cn=univention,dc=rent24,dc=com
17207 actions.upgrade 18-07-08 16:04:05 [ INFO]: Running 50dudle.inst skipped (already executed)
10485 actions.register 18-07-09 11:54:21 [ INFO]: No hostdn for dudle found. Nothing to remove
10724 actions.register 18-07-09 11:55:15 [ INFO]: No hostdn for dudle found. Nothing to remove
25999 actions.register 18-07-09 14:07:25 [ INFO]: No hostdn for dudle found. Nothing to remove
Andere, dudle spezifische Logs sind noch vor der aufsetzung der VM entstanden, also noch von euch
also die neue Version von dudle (1.2.0-1) gibt es nur für UCS 4.3. Auf meinem UCS 4.2-4 UCS Master mit dudle=1.1.0-1 wird in der UMC auch kein Update angezeigt. Wo siehst du die Meldung “1.1.0-1 installed. Upgrade to 1.2.0-1 available”?
Vielleicht ist es ein Problem wenn man im AppCenter auf einem UCS 4.3 ist und dort eine App für einen anderen Rechner mit UCS 4.2 anschaut.
Wie auch immer, auf 4.2 kann die aktuelle dudle nicht installiert werden.
VG
Felix
Hallo @botner,
auf dem Server, welcher 4.3-1 ist, dort ist es auch installiert:
Unter App-Center aktualisierungen fehlt es allerdings:
Sind jetzt auf 4.3-2 und der Fehler tritt immer noch auf
Gibt es eine Möglichkeit es zu reparieren oder hilft nur uninstall und reinstall?
Besten Dank und viele Grüße
Seems the App is in some unconventional state.
Listened as installed, but not running and not upgradeable:
dudle
Latest version: 1.2.0-1
Installations: ucs.xxx.com
But not listened as Docker image
Ein Fehler ist aufgetreten: No container found. Unable to run store_data!
Weitere Hinweise finden Sie in der folgenden Logdatei auf den beteiligten Systemen:
*/var/log/univention/appcenter.log*
No meaning of dudle in log.
And not uninstallable
