Domänenbeitritt NextCloud / OwnCloud
Guten Morgen,
hat jemand das gleiche Problem dass der Domänenbeitritt in OwnCloud / NextCloud mit den aktuellsten ESX-Images fehl schlägt?
Join-Protokoll
5b476c50 OVER: Loading Translog Overlay
5b476c50 Loading shadowbind Overlay.OVER: db_init
5b476c50 OVER: Configuring Translog Overlay
5b476c50 OVER: Configured Translog Overlay to use file "/var/lib/univention-ldap/listener/listener"
5b476c50 shadowbind_db_init
5b476c50 shadowbind_db_config
5b476c50 shadowbind_db_open
5b476c51 OVER: db_close
5b476c51 shadowbind_db_destroy
5b476c51 OVER: db_destroy
12.07.18 16:58:06.190 DEBUG_INIT
12.07.18 17:00:47.267 DEBUG_INIT
cp: der Aufruf von stat für '' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Do 12. Jul 17:04:58 CEST 2018
RUNNING 01univention-ldap-server-init.inst
EXITCODE=already_executed
RUNNING 02univention-directory-notifier.inst
RUNNING 03univention-directory-listener.inst
RUNNING 04univention-ldap-client.inst
RUNNING 05univention-bind.inst
RUNNING 08univention-apache.inst
RUNNING 10univention-ldap-server.inst
RUNNING 11univention-heimdal-init.inst
RUNNING 11univention-pam.inst
RUNNING 15univention-directory-notifier-post.inst
RUNNING 15univention-heimdal-kdc.inst
RUNNING 18python-univention-directory-manager.inst
RUNNING 20univention-directory-policy.inst
RUNNING 20univention-join.inst
RUNNING 26univention-nagios-common.inst
RUNNING 26univention-samba.inst
2018-07-12 17:04:58.710832716+02:00 (in joinscript_init)
INFO: Cannot run joinscript in memberserver mode without join credentials. Please run:
univention-run-join-scripts --ask-pass
to complete the domain join.
EXITCODE=2
RUNNING 30univention-appcenter.inst
RUNNING 30univention-nagios-client.inst
RUNNING 31univention-nagios-ad-connector.inst
RUNNING 33univention-portal.inst
RUNNING 34univention-management-console-server.inst
RUNNING 35univention-appcenter-docker.inst
RUNNING 35univention-management-console-module-adconnector.inst
RUNNING 35univention-management-console-module-appcenter.inst
RUNNING 35univention-management-console-module-diagnostic.inst
RUNNING 35univention-management-console-module-ipchange.inst
RUNNING 35univention-management-console-module-join.inst
RUNNING 35univention-management-console-module-lib.inst
RUNNING 35univention-management-console-module-mrtg.inst
RUNNING 35univention-management-console-module-quota.inst
RUNNING 35univention-management-console-module-reboot.inst
RUNNING 35univention-management-console-module-services.inst
RUNNING 35univention-management-console-module-setup.inst
RUNNING 35univention-management-console-module-sysinfo.inst
RUNNING 35univention-management-console-module-top.inst
RUNNING 35univention-management-console-module-ucr.inst
RUNNING 35univention-management-console-module-udm.inst
RUNNING 35univention-management-console-module-updater.inst
RUNNING 35univention-server-overview.inst
RUNNING 36univention-management-console-module-apps.inst
RUNNING 40univention-virtual-machine-manager-schema.inst
RUNNING 81univention-ad-connector.inst
RUNNING 81univention-nfs-server.inst
RUNNING 90univention-bind-post.inst
RUNNING 91univention-saml.inst
RUNNING 92univention-management-console-web-server.inst
RUNNING 51owncloud-uninstall.uinst
2018-07-12 17:05:03.712940376+02:00 (in joinscript_init)
WARNING: cannot remove ownCloud from service, value does not exist
No modification: cn=SRVOWNCLOUD,cn=dc,cn=computers,dc=xxxxxxxxxxxxxx,dc=local
Unsetting owncloud/group/enabled
Unsetting owncloud/ldap/base/groups
Unsetting owncloud/ldap/base/users
Unsetting owncloud/ldap/emailAttribute
Unsetting owncloud/ldap/groupFilter
Unsetting owncloud/ldap/groupUuid
Unsetting owncloud/ldap/internalNameAttribute
Unsetting owncloud/ldap/loginFilter
Unsetting owncloud/ldap/memberAssoc
Unsetting owncloud/ldap/search/groups
Unsetting owncloud/ldap/search/users
Unsetting owncloud/ldap/user/quotaAttribute
Unsetting owncloud/ldap/userFilter
Unsetting owncloud/ldap/userUuid
Unsetting owncloud/user/enabled
Unsetting owncloud_ldap_agentpassword
[05.UNJOIN] Dropping ownCloud admin docs...
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/description' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/description/de' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/label' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/label/de' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/link' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-admindoc/priority' does not exist
Unsetting ucs/web/overview/entries/admin/owncloud-admindoc/icon
Module: create_portal_entries
[05.UNJOIN] Dropping ownCloud user docs...
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/description' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/description/de' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/label' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/label/de' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/link' does not exist
W: The config registry variable 'ucs/web/overview/entries/admin/owncloud-userdoc/priority' does not exist
Unsetting ucs/web/overview/entries/admin/owncloud-userdoc/icon
E: object not found
[05.UNJOIN] Dropping ownCloud database...
[05.UNJOIN] removing owncloud.secret file
EXITCODE=0
Do 12. Jul 17:05:06 CEST 2018
Do 12. Jul 17:05:24 CEST 2018
2018-07-12 17:05:25.350966965+02:00 (in joinscript_init)
EXITCODE=2
Do 12. Jul 17:05:27 CEST 2018
Do 12. Jul 17:09:11 CEST 2018
2018-07-12 17:09:11.498354092+02:00 (in joinscript_init)
EXITCODE=2
Do 12. Jul 17:09:12 CEST 2018
Do 12. Jul 17:09:23 CEST 2018
2018-07-12 17:09:23.465612487+02:00 (in joinscript_init)
EXITCODE=2
Do 12. Jul 17:09:24 CEST 2018
Fr 13. Jul 08:55:26 CEST 2018
2018-07-13 08:55:26.302111117+02:00 (in joinscript_init)
EXITCODE=2
Danke für eure Hilfe
aktuell sind mir hier keine Probleme bekannt. Mir ist noch nicht ganz klar, welches Image verwendet wurde. Eine App Appliance, in der die App schon vorinstalliert ist, oder ein normales UCS ins AD gejoined, in das die Apps dann nachinstalliert wurden?
