wir haben ein ganz dringendes und akutes Problem, denn User können sich von einem auf den anderen Moment nicht mehr an der Domäne anmelden. Netzwerkproblem sind auszuschleissen. Kann mich per ssh auf dem Master einloggen. Merkwürdigerweise erschein bei der Eingabe von “smbstatus” folgendes.
Global parameter ldap idmap suffix found in service section!
Global parameter idmap uid found in service section!
Global parameter idmap gid found in service section!
Global parameter winbind trusted domains only found in service section!
Global parameter winbind enum users found in service section!
Global parameter winbind enum groups found in service section!
Global parameter winbind separator found in service section!
Global parameter template shell found in service section!
Global parameter template homedir found in service section!
Global parameter pam password change found in service section!
Global parameter unix password sync found in service section!
Global parameter passwd program found in service section!
Global parameter passwd chat found in service section!
Global parameter passwd chat timeout found in service section!
Global parameter obey pam restrictions found in service section!
Global parameter encrypt passwords found in service section!
Global parameter load printers found in service section!
Global parameter printcap name found in service section!
Global parameter security found in service section!
Global parameter domain logons found in service section!
Global parameter domain master found in service section!
Global parameter preferred master found in service section!
Global parameter local master found in service section!
Global parameter os level found in service section!
Global parameter wins support found in service section!
Global parameter workgroup found in service section!
Global parameter kernel oplocks found in service section!
Global parameter large readwrite found in service section!
Global parameter deadtime found in service section!
Global parameter read raw found in service section!
Global parameter write raw found in service section!
Global parameter max xmit found in service section!
Global parameter getwd cache found in service section!
Global parameter logon home found in service section!
Global parameter logon drive found in service section!
Global parameter logon path found in service section!
Global parameter time server found in service section!
Global parameter host msdfs found in service section!
Global parameter guest account found in service section!
Global parameter map to guest found in service section!
Global parameter set quota command found in service section!
Global parameter add user script found in service section!
Global parameter delete user script found in service section!
Global parameter add group script found in service section!
Global parameter delete group script found in service section!
Global parameter add user to group script found in service section!
Global parameter delete user from group script found in service section!
Global parameter add machine script found in service section!
Global parameter set primary group script found in service section!
Samba version 3.0.23d
PID Username Group Machine
Service pid machine Connected at
No locked files
Ich meine, dass die Angaben der Global Parameter dort sonst nicht gestanden hätten.
ps -ax liefert
PID TTY STAT TIME COMMAND
1 ? Ss 0:01 init [2]
2 ? S 0:00 [migration/0]
3 ? SN 0:00 [ksoftirqd/0]
4 ? S 0:00 [migration/1]
5 ? SN 0:00 [ksoftirqd/1]
6 ? S< 0:00 [events/0]
7 ? S< 0:00 [events/1]
8 ? S< 0:00 [khelper]
9 ? S< 0:00 [kthread]
13 ? S< 0:00 [kblockd/0]
14 ? S< 0:00 [kblockd/1]
15 ? S< 0:00 [kacpid]
118 ? S< 0:00 [kseriod]
178 ? S 0:00 [pdflush]
179 ? S 0:00 [pdflush]
180 ? S< 0:00 [kswapd0]
181 ? S< 0:00 [aio/0]
182 ? S< 0:00 [aio/1]
183 ? S< 0:00 [cifsoplockd]
184 ? S< 0:00 [cifsdnotifyd]
185 ? S< 0:00 [xfslogd/0]
186 ? S< 0:00 [xfslogd/1]
187 ? S< 0:00 [xfsdatad/0]
188 ? S< 0:00 [xfsdatad/1]
831 ? S< 0:00 [ata/0]
832 ? S< 0:00 [ata/1]
833 ? S< 0:00 [ata_aux]
835 ? S< 0:00 [scsi_eh_0]
836 ? S< 0:00 [scsi_eh_1]
837 ? S< 0:00 [scsi_eh_2]
838 ? S< 0:00 [scsi_eh_3]
884 ? S< 0:00 [kpsmoused]
890 ? S 0:00 [kirqd]
958 ? S< 0:00 [khubd]
1039 ? S< 0:00 [kjournald]
1351 ? S< 0:00 [md0_raid1]
1378 ? S< 0:00 [kjournald]
1380 ? S< 0:00 [kjournald]
1382 ? S< 0:00 [kjournald]
1384 ? S< 0:00 [kjournald]
1501 ? Ss 0:00 /sbin/portmap
1581 ? Ss 0:00 /sbin/syslogd -m0
1584 ? Ss 0:00 /sbin/klogd -c2
1588 ? Ss 0:00 runsvdir /var/service log: .......................................................................................................
1592 ? S 0:00 runsv univention-bind
1593 ? S 0:00 runsv univention-ldap-listener
1594 ? S 0:00 runsv univention-ldap-notifier
1595 ? S 0:00 runsv univention-dhcp
1596 ? S 0:00 runsv univention-bind-proxy
1603 ? Ss 0:00 /usr/sbin/slapd -h ldap:/// ldapi:/// ldaps:///
1618 ? Ss 0:00 /usr/sbin/spamd -m 10 -H -d --pidfile=/var/run/spamd.pid
1625 ? Ss 0:00 /usr/sbin/cupsd -F
1641 ? S 0:00 spamd child
1642 ? S 0:00 spamd child
1643 ? Ss 0:00 /usr/sbin/cyrmaster -d
1649 ? Ss 0:00 /usr/bin/dbus-daemon-1 --system
1653 ? Ss 0:00 /usr/lib/heimdal-servers/kdc
1655 ? Ss 0:00 /usr/lib/heimdal-servers/kpasswdd
1662 ? Ss 0:00 /usr/sbin/inetd
1697 ? S< 0:00 [nfsd4]
1698 ? S 0:00 [nfsd]
1699 ? S 0:00 [nfsd]
1700 ? S 0:00 [nfsd]
1701 ? S 0:00 [nfsd]
1702 ? S 0:00 [nfsd]
1703 ? S 0:00 [nfsd]
1704 ? S 0:00 [nfsd]
1705 ? S 0:00 [nfsd]
1707 ? S 0:00 [lockd]
1708 ? S< 0:00 [rpciod/0]
1709 ? S< 0:00 [rpciod/1]
1712 ? Ss 0:00 /usr/sbin/rpc.mountd
1719 ? Ss 0:00 /usr/sbin/nscd
1753 ? S 0:00 notifyd
1836 ? Ss 0:00 /usr/lib/postfix/master
1838 ? S 0:00 pickup -l -t fifo -u -c
1839 ? S 0:00 qmgr -l -t fifo -u -c
1897 ? S 0:00 /usr/lib/postgresql/bin/postmaster -D /var/lib/postgres/data
1901 ? S 0:00 postgres: stats buffer process
1902 ? S 0:00 postgres: stats collector process
1912 ? Ss 0:00 /usr/sbin/saslauthd -r -a pam
1913 ? S 0:00 /usr/sbin/saslauthd -r -a pam
1914 ? S 0:00 /usr/sbin/saslauthd -r -a pam
1915 ? S 0:00 /usr/sbin/saslauthd -r -a pam
1916 ? S 0:00 /usr/sbin/saslauthd -r -a pam
1922 ? Ss 0:00 /usr/sbin/sshd
1925 ? S 0:00 /usr/sbin/named -c /etc/bind/named.conf -p 7777 -u bind -f
1929 ? S 0:00 /usr/sbin/named -c /etc/bind/named.conf.proxy -u bind -f
1933 ? S 0:00 /usr/sbin/univention-ldap-notifier -d 1 -S 500000 -F
1939 ? Ss 0:00 /sbin/rpc.statd
1946 ? SLs 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid
1949 ? Ss 0:00 /sbin/mdadm -F -i /var/run/mdadm.pid -m root -f -s
1964 ? S 0:00 /usr/sbin/apache
1971 ? Ss 0:00 /usr/sbin/nmbd -D
1973 ? Ss 0:00 /usr/sbin/smbd -D
1975 ? S 0:00 /usr/sbin/apache
1976 ? S 0:00 /usr/sbin/apache
1977 ? S 0:00 /usr/sbin/apache
1978 ? S 0:00 /usr/sbin/apache
1979 ? S 0:00 /usr/sbin/apache
1987 ? Ss 0:00 /usr/sbin/winbindd
1988 ? S 0:00 /usr/sbin/smbd -D
1990 ? S 0:00 /usr/sbin/winbindd
1995 ? Ss 0:00 /usr/sbin/atd
1998 ? Ss 0:00 /usr/sbin/cron
2029 ? S 0:00 /usr/sbin/apache
2048 tty1 Ss+ 0:00 /sbin/getty 38400 tty1
2050 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2051 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2052 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2054 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2055 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2066 ? S 0:00 /usr/sbin/univention-ldap-listener -F -b dc=gri-oekonet,dc=de -m /usr/lib/univention-ldap-listener/system -c /var/lib/univention-l
2176 ? Ss 0:00 sshd: root@pts/0
2318 pts/0 Ss 0:00 -bash
3006 pts/0 R+ 0:00 ps -ax
Es wurde absolut nicht geänder, lediglich auf einem Client der Befehl
net user username /domain
ausgeführt, um zu schauen, welche Skripts ausgeführt werden.
Kann da aber keinen Zusammenhang sehen.
Wäre schön, wenn mir da jemand Zeitnah eine Lösung anbieten könnte.
MfG
