Hello
Is it possible to generate from UCS server domain users logon/logoff time report with workstation names? This is important feature for security audits.
Best Regards
Marcin
Hello
Best Regards
Marcin
To my knowledge, that is out of the box not possible. You should be able to get this information from the samba-log, but that is much to sift through. Something like this could work:
cat /var/log/samba/log.* |grep -A 1 make_connection_snum > logons.txt
pdbedit is AFAIR also able to display logon/logoff times (maybe you can build a script from this):
pdbedit -L -v -u <username>
There should be third party tools, that also give you a report, that may be more effective.
Thank you for suggestions.
