Like the topic title says…
Thanks
Thanks
Hey,
univention-samba4
is the UCS integration package that sets up and configures Samba as an Active Directory domain controller.univention-samba
is the UCS integration package that sets up and configures Samba as a member server without domain controller functionality.univention-samba-slave-pdc
is an empty meta package pulling in the univention-samba
package, meaning the member server/non-domain controller variant. I’m actually not sure why the package has -pdc
in its name, to be honest.m.
@Moritz_Bunkus i’m asking… because i’m getting a lot of problems to add a new slave server into my “ucs active directory domain”
Normally i install the server as ucs slave, when finished
A few months back it works… now i’m trying since the last couple of days but always get a fault server…
I don’t know what can i do more… so i start think maybe something in tha packages change and should install the univention-samba4 … but from what you say i think that i still the right steps to do…
Thanks
