Hello everyone,
im playing around with the univention. My goal is to have 2 nics one is internal network and the second one is for internet connection.
So the installation was made with one nic and as a static config at the end i added the samba domain, dhcp and kde ui.
After installation i added a client in dhcp and it worked without a problem. When i added the second nic and restarted my server dhcp stopped.
I also checked /var/log/dhcp-ldap-startup.log and /var/log/daemon.log but dhcp-ldap…log is totally empty and the daemon.log only says configuration file errors encountered.
Does anyone know this problem and can give me some hints?
Best regards
