the master may fail as long as no write operations should happen at the LDAP…
In practice one will notice this quite fast. So: Minutes rather than hours.
And yes, you can “save” the master as a snapshot.
After a “restore”, please note that the backup must be rejoined, as it has a newer database than the master!
Really, that sounds nice. But at UCS basic training we were told that if the database on backup or slave a newer then master, the only way is to Upgrade the Backup to Master, and install a new backup.
