Connector example
Hello, is there an example template/connector that allows me to write a program that is able to update the passwords of users of a database?
thank you.
bb.
You might use udm from within a shell script.
Or use the REST API for this.
Hope it helps
/CV
hi, maybe I was not clear but I would need the opposite, I have to feed the database with the ucs passwords.
thank you.
there is no way. The user passwords are getting crypted/salted/hased before stored in the LDAP database.
You can read the stored values by using univention-ldapsearch or any other LDAP browser. But you will never get the real passwords.
/CV
