Command line interface
Is there a command line interface that allows you to use Linux commands? If so can anyone point to the direction on how to access the interface? I am trying ing to copy files to the sysvol and can’t seem to connect from a Windows maxhine.
I’m not quite sure what you are looking for, but if you simply need to log into the CLI environment of the UCS server, you must use an SSH client (like puTTY) from the windows machine.
