Certs porblems on ucs master
Hi, on ucs Master ucr search --brief apache2/ssl/{cert,key}:
apache2/ssl/certificate:
apache2/ssl/certificatechain:
apache2/ssl/key: /etc/univention/ssl/ucs-master.doamin.intranet/private.key
saml/apache2/ssl/certificate:
saml/apache2/ssl/certificatechain:
saml/apache2/ssl/key:
ls /etc/univention/ssl/ucs-master.doamin.intranet:
cert.pem openssl.cnf private.key req.pem
How can I fix it?
Thank you regards
