Halo,
Can you help confirming what are the directory where OX stores calendar setting in Univention?. After upgrading UCS author and reviewable permissions doesn’t seem to work anymore.
Rgds,
Rolando Riley
Halo,
Rgds,
Rolando Riley
OX stores calendar settings in the MySQL database.
The calendar received a missive update in OX server version 7.10.0 - I think it is a complete rewrite. In my experience all settings are migrated very well, but it is possible that some of your settings were mangled. Please try to unset and reset your calendar permissions, that may fix them.
Thanks Troeder,
Just received an answer from their side. For some reason they acknowledge the problem that stopped working on that version and reinstated the capability on version 7.10.1 . Will do an upgrade and see.
Rolando
