Hi Folks,
I have no clue what I’m missing.
We use BigBlueButton via NextCloud for quite some time sucessfully. On the same machine we also run a moodle connected to our UCS ldap via SSL 7636. This is working like a charm.
Now we added on the same machine greenlight and even though we are using the same ldap credentials as on moodle we can’t connect to UCS
Net::LDAP::Error (Address not available - connect(2) for [xxxxxx:5945]:7636):
I followed this description https://www.univention.de/blog-de/2020/08/how-to-videokonferenz-loesung-bigbluebutton-fuer-ucs-konfigurieren-und-einfach-nutzen/
Do I miss anything? as far as I remeber I hat to add the Root Certificate on the server to get the moodle ldap working. Do I need to do the same on the greenlight docker?
Also on the server I use the ets/hosts to resolve the internal IP of my UCS - do I need to add this on docker too? (how to do so?)
any help would be appreciated.
