Best way to change site settigns
With samba4 we have the ucr variable samba4/join/site
What is the best way to set a site after the a member server already join ?
1- remove server from domain -> set site variable -> join domain again
2- set site variable -> run join scripts with force option
3 - other options?
Thanks
Hey,
you don’t have to rejoin. Simply use the standard Windows Remote Server Administration Tools (“Active Directory Sites and Services”) and drag & drop your server into the desired site. Here is an explanation from the Samba wiki that even includes screenshots.
Kind regards
mosu
Thanks @Mosu, i get the link to… but i’m waiting someone give were some feedback before i follow that.
I will do it.
