I installed UCS with samba 3 with AD connector. I would like trust relationship between win2008 and UCS.
I set up next steps:
On the win2008
ucs-ad-connector-64bit.msi (for 64bit Windows)
Microsoft Visual C++ 2010 Redistributable Package (x86)
The private.key and cert.pem files
copied into the installation directory of the password service.
Network security: Do not store LAN Manager hash value on next password
change to Disabled
On the UCS:
Add the win2008 certificate file.
ucr set hosts/static/192.168.0.100=w2k8-32.ad.example.com
echo “iptables -I INPUT 1 -p udp --sport 137 -j ACCEPT” \
/etc/security/packetfilter.d/50_local.sh
/etc/init.d/univention-firewall restart
net rpc trustdom establish
My probem is The username or password was not correct.
Couldn’t verify trusting domain account. Error was NT_STATUS_LOGON_FAILURE
