70kopano4ucs join failed
Forgotten link
Hi, short feedback: here, we had exact the same problem:
LDAP Error: Undefined attribute type: kopanoMrAcceptRecurring: attribute type undefined
It was solved by the comment from @damrose
:blush: Thank you!
Please update the packages on the DC Master and all DC Backups via univention-app install --only-master-packages --do-not-install-master-packages-remotely kopano-core
Then, run the join scripts again.
Logs from that App update would be interesting.
From the server where the update was started (probably your DC master) and the server kopano is installed
/var/log/univention/*appcenter*.log
Hi guys…
It is 2020 and 70kopano4ucs join still failing.
I have one UCS Master and two UCS Backup.
I am using second UCS Backup to install kopano-core. 70kopano4ucs join log fail is:
RUNNING 70kopano4ucs-udm.inst
2020-04-06 11:43:29.894165221-03:00 (in joinscript_init)
Object exists: ou=Kopano Addresslists,dc=cds,dc=local
Object exists: cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopano,dc=cds,dc=local
Object exists: cn=contacts,cn=kopano,dc=cds,dc=local
Object exists: cn=non-active,cn=kopano,dc=cds,dc=local
Object exists: cn=kopano-group,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopano-group-hidden,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopano-group-sendas,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopano-role,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=k4uUserSendAsPrivilege,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=SendAsPrivilege,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopano-user-hidden,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=MRAccept,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=MRProcess,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=MRAcceptConflictingTimes,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=MRAcceptRecurringItems,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=quotaOverride,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=quotaWarn,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=quotaSoft,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=quotaHard,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopanoEnabledFeature,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
Object exists: cn=kopanoDisabledFeature,cn=kopano,cn=custom attributes,cn=univention,dc=cds,dc=local
EXITCODE=3
697994c1-0317-497a-a1d0-52b2f871d1c6
univention-join-hooks: looking for hook type "join/post-joinscripts" on ucs01.cds.local
Found hooks:
seg abr  6 11:43:36 -03 2020
As @damrose sugested i run univention-app install --only-master-packages --do-not-install-master-packages-remotely kopano-core at UCS Master and both UCS Backup. But 70kopano4UCS join still fail.
Is there another update for this problem?
Hi @nathanielmorais,
please provide the information requested earlier:
In addition the exact versions of software used could be interesting. You can get this when running (on all involved systems):
# exactly installed versions:
dpkg -l | grep -w 'kopano4ucs\|kopano-server-packages\|kopano-webapp\|z-push-kopano'
# Univention version and installed app versions:
univention-app info
Thanks for the reply.
/var/log/univention/appcenter.log: appcenter.txt (1.2 MB)
dpkg -l | grep -w ‘kopano4ucs|kopano-server-packages|kopano-webapp|z-push-kopano’ :
ii  kopano-server-packages                              8.7.1.0-0+9.1                                                       all          Metapackage to install the entire Kopano Core stack
ii  kopano4ucs                                          1.6.2                                                               all          Kopano4ucs integration package for Univention Corporate Server
ii  kopano4ucs-app                                      1.6.2                                                               all          Package for UCS app specific logic
ii  kopano4ucs-lib                                      1.6.2                                                               all          Library package for common Kopano4ucs functions
ii  kopano4ucs-schema                                   1.6.2                                                               all          LDAP schema for the Kopano4ucs integration
ii  kopano4ucs-udm                                      1.6.2                                                               all          UDM extensions for the Kopano4ucs integration
univention-app info:
UCS: 4.4-4 errata499
Installed: kopano-core=8.7.1.0-1 wordpress=5.2.3 4.3/etherpad-lite=1.6.6
Upgradable: etherpad-lite
Please run the commands on all of your systems.
At DC Master (ucs01):
Appcenter.log: appcenter.log.ucs01.txt (231.1 KB)
no output
At DC Backup (ucs02):
appcenter.log: appcenter.log.ucs02.txt (351.8 KB)
no output
At DC Backup (ucs03):
appcenter.log: appcenter.log.ucs03.txt (1.2 MB)
This indicates the integration packages are missing on your master. Did you really run univention-app install --only-master-packages kopano-core on your master?
Yes i did on my Master.
I run the command again and this is the output:
# univention-app install --only-master-packages --do-not-install-master-packages-remotely kopano-core
Going to install Kopano Core (8.7.1.0-1)
Press [ENTER] to continue
Registering component for kopano-core=8.7.1.0-1
File: /etc/apt/sources.list.d/20_ucs-online-component.list
File: /etc/apt/mirror.list
File: /etc/apt/sources.list.d/15_ucs-online-version.list
Ign:1 http://updates.software-univention.de/4.0/maintained 4.0-0/all/ InRelease
Ign:2 http://updates.software-univention.de/4.0/maintained 4.0-0/i386/ InRelease
Ign:3 http://updates.software-univention.de/4.0/maintained 4.0-0/amd64/ InRelease
Ign:4 http://updates.software-univention.de/4.0/maintained 4.0-1/all/ InRelease
Ign:5 http://updates.software-univention.de/4.0/maintained 4.0-1/i386/ InRelease
Ign:6 http://updates.software-univention.de/4.0/maintained 4.0-1/amd64/ InRelease
Ign:7 http://updates.software-univention.de/4.0/maintained 4.0-2/all/ InRelease
Ign:8 http://updates.software-univention.de/4.0/maintained 4.0-2/i386/ InRelease
Ign:9 http://updates.software-univention.de/4.0/maintained 4.0-2/amd64/ InRelease
Ign:10 http://updates.software-univention.de/4.0/maintained 4.0-3/all/ InRelease
Ign:11 http://updates.software-univention.de/4.0/maintained 4.0-3/i386/ InRelease
Ign:12 http://updates.software-univention.de/4.0/maintained 4.0-3/amd64/ InRelease
Ign:13 http://updates.software-univention.de/4.0/maintained 4.0-4/all/ InRelease
Ign:14 http://updates.software-univention.de/4.0/maintained 4.0-4/i386/ InRelease
Ign:15 http://updates.software-univention.de/4.0/maintained 4.0-4/amd64/ InRelease
Ign:16 http://updates.software-univention.de/4.0/maintained 4.0-5/all/ InRelease
Ign:17 http://updates.software-univention.de/4.0/maintained 4.0-5/i386/ InRelease
Ign:18 http://updates.software-univention.de/4.0/maintained 4.0-5/amd64/ InRelease
Ign:19 http://updates.software-univention.de/4.1/maintained 4.1-0/all/ InRelease
Ign:20 http://updates.software-univention.de/4.1/maintained 4.1-0/i386/ InRelease
Ign:21 http://updates.software-univention.de/4.1/maintained 4.1-0/amd64/ InRelease
Ign:22 http://updates.software-univention.de/4.1/maintained 4.1-1/all/ InRelease
Ign:23 http://updates.software-univention.de/4.1/maintained 4.1-1/i386/ InRelease
Ign:24 http://updates.software-univention.de/4.1/maintained 4.1-1/amd64/ InRelease
Ign:25 http://updates.software-univention.de/4.1/maintained 4.1-2/all/ InRelease
Ign:26 http://updates.software-univention.de/4.1/maintained 4.1-2/i386/ InRelease
Ign:27 http://updates.software-univention.de/4.1/maintained 4.1-2/amd64/ InRelease
Ign:28 http://updates.software-univention.de/4.1/maintained 4.1-3/all/ InRelease
Ign:29 http://updates.software-univention.de/4.1/maintained 4.1-3/i386/ InRelease
Ign:30 http://updates.software-univention.de/4.1/maintained 4.1-3/amd64/ InRelease
Ign:31 http://updates.software-univention.de/4.1/maintained 4.1-4/all/ InRelease
Ign:32 http://updates.software-univention.de/4.1/maintained 4.1-4/i386/ InRelease
Ign:33 http://updates.software-univention.de/4.1/maintained 4.1-4/amd64/ InRelease
Ign:34 http://updates.software-univention.de/4.1/maintained 4.1-5/all/ InRelease
Ign:35 http://updates.software-univention.de/4.1/maintained 4.1-5/i386/ InRelease
Ign:36 http://updates.software-univention.de/4.1/maintained 4.1-5/amd64/ InRelease
Ign:37 http://updates.software-univention.de/4.2/maintained 4.2-0/all/ InRelease
Ign:38 http://updates.software-univention.de/4.2/maintained 4.2-0/i386/ InRelease
Ign:39 http://updates.software-univention.de/4.2/maintained 4.2-0/amd64/ InRelease
Ign:40 http://updates.software-univention.de/4.2/maintained 4.2-1/all/ InRelease
Ign:41 http://updates.software-univention.de/4.2/maintained 4.2-1/i386/ InRelease
Ign:42 http://updates.software-univention.de/4.2/maintained 4.2-1/amd64/ InRelease
Ign:43 http://updates.software-univention.de/4.2/maintained 4.2-2/all/ InRelease
Ign:44 http://updates.software-univention.de/4.2/maintained 4.2-2/i386/ InRelease
Ign:45 http://updates.software-univention.de/4.2/maintained 4.2-2/amd64/ InRelease
Ign:46 http://updates.software-univention.de/4.2/maintained 4.2-3/all/ InRelease
Ign:47 http://updates.software-univention.de/4.2/maintained 4.2-3/i386/ InRelease
Ign:48 http://updates.software-univention.de/4.2/maintained 4.2-3/amd64/ InRelease
Ign:49 http://updates.software-univention.de/4.2/maintained 4.2-4/all/ InRelease
Ign:50 http://updates.software-univention.de/4.2/maintained 4.2-4/i386/ InRelease
Ign:51 http://updates.software-univention.de/4.2/maintained 4.2-4/amd64/ InRelease
Ign:52 http://updates.software-univention.de/4.2/maintained 4.2-5/all/ InRelease
Ign:53 http://updates.software-univention.de/4.2/maintained 4.2-5/i386/ InRelease
Ign:54 http://updates.software-univention.de/4.2/maintained 4.2-5/amd64/ InRelease
Ign:55 http://updates.software-univention.de/4.3/maintained 4.3-0/all/ InRelease
Ign:56 http://updates.software-univention.de/4.3/maintained 4.3-0/i386/ InRelease
Ign:57 http://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ InRelease
Ign:58 http://updates.software-univention.de/4.3/maintained 4.3-1/all/ InRelease
Ign:59 http://updates.software-univention.de/4.3/maintained 4.3-1/i386/ InRelease
Ign:60 http://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ InRelease
Ign:61 http://updates.software-univention.de/4.3/maintained 4.3-2/all/ InRelease
Ign:62 http://updates.software-univention.de/4.3/maintained 4.3-2/i386/ InRelease
Ign:63 http://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ InRelease
Ign:64 http://updates.software-univention.de/4.3/maintained 4.3-3/all/ InRelease
Ign:65 http://updates.software-univention.de/4.3/maintained 4.3-3/i386/ InRelease
Ign:66 http://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ InRelease
Ign:67 http://updates.software-univention.de/4.3/maintained 4.3-4/all/ InRelease
Ign:68 http://updates.software-univention.de/4.3/maintained 4.3-4/i386/ InRelease
Ign:69 http://updates.software-univention.de/4.3/maintained 4.3-4/amd64/ InRelease
Ign:70 http://updates.software-univention.de/4.3/maintained 4.3-5/all/ InRelease
Ign:71 http://updates.software-univention.de/4.3/maintained 4.3-5/i386/ InRelease
Ign:72 http://updates.software-univention.de/4.3/maintained 4.3-5/amd64/ InRelease
Ign:73 http://updates.software-univention.de/4.4/maintained 4.4-0/all/ InRelease
Ign:74 http://updates.software-univention.de/4.4/maintained 4.4-0/i386/ InRelease
Ign:75 http://updates.software-univention.de/4.4/maintained 4.4-0/amd64/ InRelease
Ign:76 http://updates.software-univention.de/4.4/maintained 4.4-1/all/ InRelease
Ign:77 http://updates.software-univention.de/4.4/maintained 4.4-1/i386/ InRelease
Ign:78 http://updates.software-univention.de/4.4/maintained 4.4-1/amd64/ InRelease
Ign:79 http://updates.software-univention.de/4.4/maintained 4.4-2/all/ InRelease
Ign:80 http://updates.software-univention.de/4.4/maintained 4.4-2/i386/ InRelease
Ign:81 http://updates.software-univention.de/4.4/maintained 4.4-2/amd64/ InRelease
Ign:82 http://updates.software-univention.de/4.4/maintained 4.4-3/all/ InRelease
Ign:83 http://updates.software-univention.de/4.4/maintained 4.4-3/i386/ InRelease
Ign:84 http://updates.software-univention.de/4.4/maintained 4.4-3/amd64/ InRelease
Ign:85 http://updates.software-univention.de/4.4/maintained 4.4-4/all/ InRelease
Ign:86 http://updates.software-univention.de/4.4/maintained 4.4-4/i386/ InRelease
Ign:87 http://updates.software-univention.de/4.4/maintained 4.4-4/amd64/ InRelease
Ign:88 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/all/ InRelease
Ign:89 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/i386/ InRelease
Ign:90 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/amd64/ InRelease
Ign:91 http://updates.software-univention.de/4.4/unmaintained/component cool-solutions/all/ InRelease
Ign:92 http://updates.software-univention.de/4.3/unmaintained/component cool-solutions/all/ InRelease
Ign:93 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/all/ InRelease
Ign:94 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/i386/ InRelease
Ign:95 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/amd64/ InRelease
Ign:96 http://updates.software-univention.de/4.1/unmaintained/component cool-solutions/all/ InRelease
Ign:97 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/all/ InRelease
Ign:98 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/i386/ InRelease
Ign:99 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/amd64/ InRelease
Atingido:100 http://updates.software-univention.de/4.0/maintained 4.0-0/all/ Release
Atingido:102 http://updates.software-univention.de/4.0/maintained 4.0-0/i386/ Release
Atingido:104 http://updates.software-univention.de/4.0/maintained 4.0-0/amd64/ Release
Atingido:106 http://updates.software-univention.de/4.0/maintained 4.0-1/all/ Release
Atingido:108 http://updates.software-univention.de/4.0/maintained 4.0-1/i386/ Release
Atingido:110 http://updates.software-univention.de/4.0/maintained 4.0-1/amd64/ Release
Atingido:112 http://updates.software-univention.de/4.0/maintained 4.0-2/all/ Release
Atingido:114 http://updates.software-univention.de/4.0/maintained 4.0-2/i386/ Release
Atingido:116 http://updates.software-univention.de/4.0/maintained 4.0-2/amd64/ Release
Atingido:118 http://updates.software-univention.de/4.0/maintained 4.0-3/all/ Release
Atingido:120 http://updates.software-univention.de/4.0/maintained 4.0-3/i386/ Release
Atingido:122 http://updates.software-univention.de/4.0/maintained 4.0-3/amd64/ Release
Atingido:124 http://updates.software-univention.de/4.0/maintained 4.0-4/all/ Release
Atingido:126 http://updates.software-univention.de/4.0/maintained 4.0-4/i386/ Release
Atingido:128 http://updates.software-univention.de/4.0/maintained 4.0-4/amd64/ Release
Atingido:130 http://updates.software-univention.de/4.0/maintained 4.0-5/all/ Release
Atingido:132 http://updates.software-univention.de/4.0/maintained 4.0-5/i386/ Release
Atingido:134 http://updates.software-univention.de/4.0/maintained 4.0-5/amd64/ Release
Atingido:136 http://updates.software-univention.de/4.1/maintained 4.1-0/all/ Release
Atingido:138 http://updates.software-univention.de/4.1/maintained 4.1-0/i386/ Release
Atingido:140 http://updates.software-univention.de/4.1/maintained 4.1-0/amd64/ Release
Atingido:142 http://updates.software-univention.de/4.1/maintained 4.1-1/all/ Release
Atingido:144 http://updates.software-univention.de/4.1/maintained 4.1-1/i386/ Release
Atingido:146 http://updates.software-univention.de/4.1/maintained 4.1-1/amd64/ Release
Atingido:148 http://updates.software-univention.de/4.1/maintained 4.1-2/all/ Release
Atingido:150 http://updates.software-univention.de/4.1/maintained 4.1-2/i386/ Release
Atingido:151 http://updates.software-univention.de/4.1/maintained 4.1-2/amd64/ Release
Atingido:154 http://updates.software-univention.de/4.1/maintained 4.1-3/all/ Release
Atingido:156 http://updates.software-univention.de/4.1/maintained 4.1-3/i386/ Release
Atingido:158 http://updates.software-univention.de/4.1/maintained 4.1-3/amd64/ Release
Atingido:160 http://updates.software-univention.de/4.1/maintained 4.1-4/all/ Release
Atingido:162 http://updates.software-univention.de/4.1/maintained 4.1-4/i386/ Release
Atingido:164 http://updates.software-univention.de/4.1/maintained 4.1-4/amd64/ Release
Atingido:166 http://updates.software-univention.de/4.1/maintained 4.1-5/all/ Release
Atingido:168 http://updates.software-univention.de/4.1/maintained 4.1-5/i386/ Release
Atingido:170 http://updates.software-univention.de/4.1/maintained 4.1-5/amd64/ Release
Atingido:171 http://updates.software-univention.de/4.2/maintained 4.2-0/all/ Release
Atingido:173 http://updates.software-univention.de/4.2/maintained 4.2-0/i386/ Release
Atingido:176 http://updates.software-univention.de/4.2/maintained 4.2-0/amd64/ Release
Atingido:178 http://updates.software-univention.de/4.2/maintained 4.2-1/all/ Release
Atingido:180 http://updates.software-univention.de/4.2/maintained 4.2-1/i386/ Release
Atingido:182 http://updates.software-univention.de/4.2/maintained 4.2-1/amd64/ Release
Atingido:184 http://updates.software-univention.de/4.2/maintained 4.2-2/all/ Release
Atingido:186 http://updates.software-univention.de/4.2/maintained 4.2-2/i386/ Release
Atingido:187 http://updates.software-univention.de/4.2/maintained 4.2-2/amd64/ Release
Atingido:190 http://updates.software-univention.de/4.2/maintained 4.2-3/all/ Release
Atingido:192 http://updates.software-univention.de/4.2/maintained 4.2-3/i386/ Release
Atingido:194 http://updates.software-univention.de/4.2/maintained 4.2-3/amd64/ Release
Atingido:196 http://updates.software-univention.de/4.2/maintained 4.2-4/all/ Release
Atingido:198 http://updates.software-univention.de/4.2/maintained 4.2-4/i386/ Release
Atingido:200 http://updates.software-univention.de/4.2/maintained 4.2-4/amd64/ Release
Atingido:202 http://updates.software-univention.de/4.2/maintained 4.2-5/all/ Release
Atingido:204 http://updates.software-univention.de/4.2/maintained 4.2-5/i386/ Release
Atingido:206 http://updates.software-univention.de/4.2/maintained 4.2-5/amd64/ Release
Atingido:208 http://updates.software-univention.de/4.3/maintained 4.3-0/all/ Release
Atingido:210 http://updates.software-univention.de/4.3/maintained 4.3-0/i386/ Release
Atingido:212 http://updates.software-univention.de/4.3/maintained 4.3-0/amd64/ Release
Atingido:214 http://updates.software-univention.de/4.3/maintained 4.3-1/all/ Release
Atingido:216 http://updates.software-univention.de/4.3/maintained 4.3-1/i386/ Release
Atingido:218 http://updates.software-univention.de/4.3/maintained 4.3-1/amd64/ Release
Atingido:220 http://updates.software-univention.de/4.3/maintained 4.3-2/all/ Release
Atingido:222 http://updates.software-univention.de/4.3/maintained 4.3-2/i386/ Release
Atingido:224 http://updates.software-univention.de/4.3/maintained 4.3-2/amd64/ Release
Atingido:226 http://updates.software-univention.de/4.3/maintained 4.3-3/all/ Release
Atingido:228 http://updates.software-univention.de/4.3/maintained 4.3-3/i386/ Release
Atingido:230 http://updates.software-univention.de/4.3/maintained 4.3-3/amd64/ Release
Atingido:232 http://updates.software-univention.de/4.3/maintained 4.3-4/all/ Release
Atingido:234 http://updates.software-univention.de/4.3/maintained 4.3-4/i386/ Release
Atingido:236 http://updates.software-univention.de/4.3/maintained 4.3-4/amd64/ Release
Atingido:238 http://updates.software-univention.de/4.3/maintained 4.3-5/all/ Release
Atingido:240 http://updates.software-univention.de/4.3/maintained 4.3-5/i386/ Release
Atingido:242 http://updates.software-univention.de/4.3/maintained 4.3-5/amd64/ Release
Atingido:244 http://updates.software-univention.de/4.4/maintained 4.4-0/all/ Release
Atingido:246 http://updates.software-univention.de/4.4/maintained 4.4-0/i386/ Release
Atingido:248 http://updates.software-univention.de/4.4/maintained 4.4-0/amd64/ Release
Atingido:250 http://updates.software-univention.de/4.4/maintained 4.4-1/all/ Release
Atingido:252 http://updates.software-univention.de/4.4/maintained 4.4-1/i386/ Release
Atingido:254 http://updates.software-univention.de/4.4/maintained 4.4-1/amd64/ Release
Atingido:256 http://updates.software-univention.de/4.4/maintained 4.4-2/all/ Release
Atingido:258 http://updates.software-univention.de/4.4/maintained 4.4-2/i386/ Release
Atingido:260 http://updates.software-univention.de/4.4/maintained 4.4-2/amd64/ Release
Atingido:262 http://updates.software-univention.de/4.4/maintained 4.4-3/all/ Release
Atingido:264 http://updates.software-univention.de/4.4/maintained 4.4-3/i386/ Release
Atingido:266 http://updates.software-univention.de/4.4/maintained 4.4-3/amd64/ Release
Atingido:268 http://updates.software-univention.de/4.4/maintained 4.4-4/all/ Release
Atingido:270 http://updates.software-univention.de/4.4/maintained 4.4-4/i386/ Release
Atingido:272 http://updates.software-univention.de/4.4/maintained 4.4-4/amd64/ Release
Atingido:274 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/all/ Release
Atingido:276 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/i386/ Release
Atingido:278 http://updates.software-univention.de/4.4/maintained/component 4.4-4-errata/amd64/ Release
Atingido:280 http://updates.software-univention.de/4.4/unmaintained/component cool-solutions/all/ Release
Atingido:282 http://updates.software-univention.de/4.3/unmaintained/component cool-solutions/all/ Release
Atingido:284 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/all/ Release
Atingido:286 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/i386/ Release
Atingido:288 http://updates.software-univention.de/4.2/unmaintained/component cool-solutions/amd64/ Release
Atingido:290 http://updates.software-univention.de/4.1/unmaintained/component cool-solutions/all/ Release
Atingido:292 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/all/ Release
Atingido:294 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/i386/ Release
Atingido:296 http://updates.software-univention.de/4.0/unmaintained/component cool-solutions/amd64/ Release
Lendo listas de pacotes...
Construindo árvore de dependências...
Lendo informação de estado...
E: Impossível encontrar o pacote kopano4ucs-udm
Unregistering component for kopano-core=8.7.1.0-1
Atingido:133 http://updates.software-univention.de/4.0/maintained 4.0-5/amd64/ Release
Atingido:152 http://updates.software-univention.de/4.1/maintained 4.1-2/amd64/ Release
Atingido:172 http://updates.software-univention.de/4.2/maintained 4.2-0/all/ Release
Atingido:177 http://updates.software-univention.de/4.2/maintained 4.2-1/all/ Release
Atingido:188 http://updates.software-univention.de/4.2/maintained 4.2-2/amd64/ Release
Atingido:279 http://updates.software-univention.de/4.4/unmaintained/component cool-solutions/all/ Release
Atingido:281 http://updates.software-univention.de/4.3/unmaintained/component cool-solutions/all/ Release
   This app now has a new possibility to enable the [1]official Kopano
   package repositories. For this you have to click on the App Settings
   button in the Univention App Center and can then easily configure the
   desired repository from there.
   Once the repository has been activated updates can easily be installed by
   going to Software update and the executing check for package updates.
References
   Visible links
   1. https://wiki.z-hub.io/display/K4U/Updating+Kopano+packages+directly+from+the+Kopano+download+server
And come back to bash.
hm…for whatever reason it does not seem to add the app package repository to the system and then as a consequence does not find the packages it provides.
A workaround would be to temporarily add the repository manually and then run the command again. Something like this:
echo "deb [trusted=yes] https://repo.z-hub.io/kopano4ucs/Univention_4.4/ /" >> /etc/apt/sources.list.d/delete-me-afterwards.list
My UCS Servers are under proxy. I can download .deb packages from https://repo.z-hub.io/kopano4ucs/Univention_4.4/ using wget, but wen i do apt-get update it returns Connection timed out after 120000 milliseconds.
My problem: the proxy server is managed by another team, that will troubleshoot this connection at next monday.
My question: can i download all .deb packages using wget and install using dpkg -i?
yes, you cloud also download the packages manually. but you won’t need all of them. From the top of my head I don’t remember the exact dependencies but start with kopano4ucs-udm and then install the dependencies it asks for.
