ich reiße das Thema nochmal auf.
Nach dem Update auf 3.1-1 scheint die Config sich überschrieben zu haben.
Viren werden geprüft, Spam nicht…
# univention-config-registry.
# Please edit the following file(s) instead:
# univention-config-registry überschrieben werden.
# Bitte bearbeiten Sie an Stelle dessen die folgende(n) Datei(en):
# /etc/univention/templates/files/etc/amavis/conf.d/60-univention
use strict;
# Configuration file for amavisd-new
# Defaults modified for the Debian amavisd-new package
# $Id: amavisd.conf,v 1.1.1.2.2.6.10.10 2006/08/03 09:44:47 wolf Exp $
# This software is licensed under the GNU General Public License (GPL).
# See comments at the start of amavisd-new for the whole license text.
#Sections:
# Section I - Essential daemon and MTA settings
# Section II - MTA specific
# Section III - Logging
# Section IV - Notifications/DSN, BOUNCE/REJECT/DROP/PASS destiny, quarantine
# Section V - Per-recipient and per-sender handling, whitelisting, etc.
# Section VI - Resource limits
# Section VII - External programs, virus scanners, SpamAssassin
# Section VIII - Debugging
#GENERAL NOTES:
# This file is a normal Perl code, interpreted by Perl itself.
# - make sure this file (or directory where it resides) is NOT WRITABLE
# by mere mortals, otherwise it represents a severe security risk!
# - for values which are interpreted as booleans, it is recommended
# to use 1 for true, and 0 or undef or '' for false.
# THIS IS DIFFERENT FROM OLDER AMAVIS VERSIONS where "no" also meant false,
# now it means true, like any nonempty string does!
# - Perl syntax applies. Most notably: strings in "" may include variables
# (which start with $ or @); to include characters @ and $ in double
# quoted strings, precede them by a backslash; in single-quoted strings
# the $ and @ lose their special meaning, so it is usually easier to use
# single quoted strings. Still, in both cases backslash needs to be doubled.
# - variables with names starting with a '@' are lists, the values assigned
# to them should be lists as well, e.g. ('one@foo', $mydomain, "three");
# note the comma-separation and parenthesis. If strings in the list
# do not contain spaces nor variables, a Perl operator qw() may be used
# as a shorthand to split its argument on whitespace and produce a list
# of strings, e.g. qw( one@foo example.com three ); Note that the argument
# to qw is quoted implicitly and no variable interpretation is done within
# (no '$' variable evaluations). The #-initiated comments can not be used
# within the string. In other words, $ and # lose their special meaning
# within a qw argument, just like within '...' strings.
# - all e-mail addresses in this file and as used internally by the daemon
# are in their raw (rfc2821-unquoted and nonbracketed) form, i.e.
# Bob "Funny" Dude@example.com, not: "Bob \"Funny\" Dude"@example.com
# and not <"Bob \"Funny\" Dude"@example.com>; also: '' and not '<>'.
# $MYHOME serves as a quick default for some other configuration settings.
# More refined control is available with each individual setting further down.
# $MYHOME is not used directly by the program. No trailing slash!
$MYHOME = '/var/lib/amavis'; # (default is '/var/amavis')
# $mydomain serves as a quick default for some other configuration settings.
# $mydomain is never used directly by the program.
$mydomain = 'domain.de'; # (no useful default)
$myhostname = 'mail.domain.de'; # fqdn of this host
# Set the user and group to which the daemon will change if started as root
# (otherwise just keeps the UID unchanged, and these settings have no effect):
$daemon_user = 'amavis'; # (no default (undef))
$daemon_group = 'amavis'; # (no default (undef))
# Runtime working directory (cwd), and a place where
# temporary directories for unpacking mail are created.
# if you change this, you might want to modify the cleanup()
# function in /etc/init.d/amavisd-new
# (no trailing slash, may be a scratch file system)
$TEMPBASE = $MYHOME; # (must be set if other config vars use is)
#$TEMPBASE = "$MYHOME/tmp"; # prefer to keep home dir /var/amavis clean?
# $helpers_home sets environment variable HOME, and is passed as option
# 'home_dir_for_helpers' to Mail::SpamAssassin::new. It should be a directory
# on a normal persistent file system, not a scratch or temporary file system
#$helpers_home = $MYHOME; # (defaults to $MYHOME)
# Run the daemon in the specified chroot jail if nonempty:
#$daemon_chroot_dir = $MYHOME; # (default is undef, meaning: do not chroot)
$pid_file = "/var/run/amavis/amavisd.pid"; # (default: "$MYHOME/amavisd.pid")
$lock_file = "/var/run/amavis/amavisd.lock"; # (default: "$MYHOME/amavisd.lock")
# set environment variables if you want (no defaults):
$ENV{TMPDIR} = $TEMPBASE; # wise, but usually not necessary
#$protocol = "AM.PDP"; # Use AM.PDP protocol.
# MTA SETTINGS, UNCOMMENT AS APPROPRIATE,
# both $forward_method and $notify_method default to 'smtp:127.0.0.1:10025'
# POSTFIX, or SENDMAIL in dual-MTA setup, or EXIM V4
# (set host and port number as required; host can be specified
# as IP address or DNS name (A or CNAME, but MX is ignored)
#$forward_method = 'smtp:127.0.0.1:10025'; # where to forward checked mail
#$notify_method = $forward_method; # where to submit notifications
# NOTE: The defaults (above) are good for Postfix or dual-sendmail. You MUST
# uncomment the appropriate settings below if using other setups!
# SENDMAIL MILTER, using amavis-milter.c helper program:
# SEE amavisd-new-milter package docs FOR DEBIAN INSTRUCTIONS
#$forward_method = undef; # no explicit forwarding, sendmail does it by itself
# milter; option -odd is needed to avoid deadlocks
#$notify_method = 'pipe:flags=q argv=/usr/sbin/sendmail -Ac -i -odd -f ${sender} -- ${recipient}';
# just a thought: can we use use -Am instead of -odd ?
# SENDMAIL (old non-milter setup, as relay):
#$forward_method = 'pipe:flags=q argv=/usr/sbin/sendmail -C/etc/sendmail.orig.cf -i -f ${sender} -- ${recipient}';
# SENDMAIL (old non-milter setup, amavis.c calls local delivery agent):
#$forward_method = undef; # no explicit forwarding, amavis.c will call LDA
#$notify_method = 'pipe:flags=q argv=/usr/sbin/sendmail -Ac -i -f ${sender} -- ${recipient}';
# EXIM v3 (not recommended with v4 or later, which can use SMTP setup instead):
#$forward_method = 'pipe:flags=q argv=/usr/sbin/exim -oMr scanned-ok -i -f ${sender} -- ${recipient}';
# prefer to collect mail for forwarding as BSMTP files?
#$forward_method = "bsmtp:$MYHOME/out-%i-%n.bsmtp";
# Net::Server pre-forking settings
# You may want $max_servers to match the width of your MTA pipe
# feeding amavisd, e.g. with Postfix the 'Max procs' field in the
# master.cf file, like the '2' in the: smtp-amavis unix - - n - 2 smtp
$max_servers = 2; # number of pre-forked children (default 2)
$max_requests = 10; # retire a child after that many accepts (default 10)
$child_timeout=5*60; # abort child if it does not complete each task in n sec
# (default: 8*60 seconds)
# Check also the settings of @av_scanners at the end if you want to use
# virus scanners. If not, you may want to delete the whole long assignment
# to the variable @av_scanners, which will also remove the virus checking
# code (e.g. if you only want to do spam scanning).
# Here is a QUICK WAY to completely DISABLE some sections of code
# that WE DO NOT WANT (it won't even be compiled-in).
# For more refined controls leave the following two lines commented out,
# and see further down what these two lookup lists really mean.
# @bypass_virus_checks_acl = qw( . ); # uncomment to DISABLE anti-virus code
# @bypass_spam_checks_acl = qw( . ); # uncomment to DISABLE anti-spam code
# Any setting can be changed with a new assignment, so make sure
# you do not unintentionally override these settings further down!
# @bypass_spam_checks_acl = qw( . ); # No default dependency on spamassassin
# Lookup list of local domains (see README.lookups for syntax details)
# NOTE:
# For backwards compatibility the variable names @local_domains (old) and
# @local_domains_acl (new) are synonyms. For consistency with other lookups
# the name @local_domains_acl is now preferred. It also makes it more
# obviously distinct from the new %local_domains hash lookup table.
# local_domains* lookup tables are used in deciding whether a recipient
# is local or not, or in other words, if the message is outgoing or not.
# This affects inserting spam-related headers for local recipients,
# limiting recipient virus notifications (if enabled) to local recipients,
# in deciding if address extension may be appended, and in SQL lookups
# for non-fqdn addresses. Set it up correctly if you need features
# that rely on this setting (or just leave empty otherwise).
# With Postfix (2.0) a quick reminder on what local domains normally are:
# a union of domains specified in: $mydestination, $virtual_alias_domains,
# $virtual_mailbox_domains, and $relay_domains.
@local_domains_acl = qw( domain.de ); # hosted mail domains
# @local_domains_acl = ( ".$mydomain" ); # $mydomain and its subdomains
# @local_domains_acl = ( ".$mydomain", "my.other.domain" );
# @local_domains_acl = qw(); # default is empty, no recipient treated as local
# @local_domains_acl = qw( .example.com );
# @local_domains_acl = qw( .example.com !host.sub.example.net .sub.example.net );
# or alternatively(A), using a Perl hash lookup table, which may be assigned
# directly, or read from a file, one domain per line; comments and empty lines
# are ignored, a dot before a domain name implies its subdomains:
#read_hash(\%local_domains, '/etc/amavis/local_domains');
#or alternatively(B), using a list of regular expressions:
# $local_domains_re = new_RE( qr'[@.]example\.com$'i );
# see README.lookups for syntax and semantics
# Section II - MTA specific (defaults should be ok)
# if $relayhost_is_client is true, the IP address in $notify_method and
# $forward_method is dynamically overridden with SMTP client peer address
# (if available), which makes it possible for several hosts to share one
# daemon. The static port number is also overridden, and is dynamically
# calculated as being one above the incoming SMTP/LMTP session port number.
# These are logged at level 3, so enable logging until you know you got it
# right.
$relayhost_is_client = 0; # (defaults to false)
$insert_received_line = 1; # behave like MTA: insert 'Received:' header
# (does not apply to sendmail/milter)
# (default is true (1) )
# AMAVIS-CLIENT PROTOCOL INPUT SETTINGS (e.g. with sendmail milter)
# (used with amavis helper clients like amavis-milter.c and amavis.c,
# NOT needed for Postfix and Exim or dual-sendmail - keep it undefined.)
$unix_socketname = "/var/lib/amavis/amavisd.sock"; # amavis helper protocol socket
# Do we receive quoted or raw addresses from the helper program?
# (does not apply to SMTP; defaults to true)
#$gets_addr_in_quoted_form = 1; # "Bob \"Funny\" Dude"@example.com
#$gets_addr_in_quoted_form = 0; # Bob "Funny" Dude@example.com
# SMTP SERVER (INPUT) PROTOCOL SETTINGS (e.g. with Postfix, Exim v4, ...)
# (used when MTA is configured to pass mail to amavisd via SMTP or LMTP)
$inet_socket_port = 10024; # accept SMTP on this local TCP port
# (default is undef, i.e. disabled)
# multiple ports may be provided: $inet_socket_port = [10024, 10026, 10028];
# SMTP SERVER (INPUT) access control
# - do not allow free access to the amavisd SMTP port !!!
# when MTA is at the same host, use the following (one or the other or both):
$inet_socket_bind = '127.0.0.1'; # limit socket bind to loopback interface
# (default is '127.0.0.1')
@inet_acl = qw( 127.0.0.1 ); # allow SMTP access only from localhost IP
# (default is qw( 127.0.0.1 ) )
# when MTA (one or more) is on a different host, use the following:
# @inet_acl = qw(127/8 10.1.0.1 10.1.0.2); # adjust the list as appropriate
# $inet_socket_bind = undef; # bind to all IP interfaces if undef
# Example1:
# @inet_acl = qw( 127/8 10/8 172.16/12 192.168/16 );
# permit only SMTP access from loopback and rfc1918 private address space
# Example2:
# @inet_acl = qw( !192.168.1.12 172.16.3.3 !172.16.3/255.255.255.0
# 127.0.0.1 10/8 172.16/12 192.168/16 );
# matches loopback and rfc1918 private address space except host 192.168.1.12
# and net 172.16.3/24 (but host 172.16.3.3 within 172.16.3/24 still matches)
# Example3:
# !172.16.3.0 !172.16.3.127 172.16.3.0/25
# !172.16.3.128 !172.16.3.255 172.16.3.128/25 );
# matches loopback and both halves of the 172.16.3/24 C-class,
# split into two subnets, except all four broadcast addresses
# for these subnets
# See README.lookups for details on specifying access control lists.
# true (e.g. 1) => syslog; false (e.g. 0) => logging to file
$DO_SYSLOG = 1; # (defaults to false)
#$SYSLOG_LEVEL = 'user.info'; # (defaults to 'mail.info')
# Log file (if not using syslog)
$LOGFILE = "/var/log/amavis.log"; # (defaults to empty, no log)
#NOTE: levels are not strictly observed and are somewhat arbitrary
# 0: startup/exit/failure messages, viruses detected
# 1: args passed from client, some more interesting messages
# 2: virus scanner output, timing
# 3: server, client
# 4: decompose parts
# 5: more debug details
#$log_level = 2; # (defaults to 0)
# Customizable template for the most interesting log file entry (e.g. with
# $log_level=0) (take care to properly quote Perl special characters like '\')
# For a list of available macros see README.customize .
# only log infected messages (useful with log level 0):
# $log_templ = '[? %#V |[? %#F ||banned filename ([%F|,])]|infected ([%V|,])]#
# [? %#V |[? %#F ||, from=[?%o|(?)|<%o>], to=[<%R>|,][? %i ||, quarantine %i]]#
# |, from=[?%o|(?)|<%o>], to=[<%R>|,][? %i ||, quarantine %i]]';
# log both infected and noninfected messages (default):
$log_templ = '[? %#V |[? %#F |[?%#D|Not-Delivered|Passed]|BANNED name/type (%F)]|INFECTED (%V)], #
[?%o|(?)|<%o>] -> [<%R>|,][? %i ||, quarantine %i], Message-ID: %m, Hits: %c';
# Select notifications text encoding when Unicode-aware Perl is converting
# text from internal character representation to external encoding (charset
# in MIME terminology). Used as argument to Perl Encode::encode subroutine.
# to be used in RFC 2047-encoded header field bodies, e.g. in Subject:
#$hdr_encoding = 'iso-8859-1'; # (default: 'iso-8859-1')
# to be used in notification body text: its encoding and Content-type.charset
#$bdy_encoding = 'iso-8859-1'; # (default: 'iso-8859-1')
# Default template texts for notifications may be overruled by directly
# assigning new text to template variables, or by reading template text
# from files. A second argument may be specified in a call to read_text(),
# specifying character encoding layer to be used when reading from the
# external file, e.g. 'utf8', 'iso-8859-1', or often just $bdy_encoding.
# Text will be converted to internal character representation by Perl 5.8.0
# or later; second argument is ignored otherwise. See PerlIO::encoding,
# Encode::PerlIO and perluniintro man pages.
# $notify_sender_templ = read_text('/var/amavis/notify_sender.txt');
# $notify_virus_sender_templ= read_text('/var/amavis/notify_virus_sender.txt');
# $notify_virus_admin_templ = read_text('/var/amavis/notify_virus_admin.txt');
# $notify_virus_recips_templ= read_text('/var/amavis/notify_virus_recips.txt');
# $notify_spam_sender_templ = read_text('/var/amavis/notify_spam_sender.txt');
# $notify_spam_admin_templ = read_text('/var/amavis/notify_spam_admin.txt');
# If notification template files are collectively available in some directory,
# use read_l10n_templates which calls read_text for each known template.
# read_l10n_templates('/etc/amavis/en_US');
# Debian available locales: en_US, pt_BR
read_l10n_templates('en_US', '/etc/amavis');
# Here is an overall picture (sequence of events) of how pieces fit together
# (only virus controls are shown, spam controls work the same way):
# bypass_virus_checks? ==> PASS
# no viruses? ==> PASS
# log virus if $log_templ is nonempty
# quarantine if $virus_quarantine_to is nonempty
# notify admin if $virus_admin (lookup) nonempty
# notify recips if $warnvirusrecip and (recipient is local or $warn_offsite)
# add address extensions if adding extensions is enabled and virus will pass
# send (non-)delivery notifications
# to sender if DSN needed (BOUNCE or ($warn_virus_sender and D_PASS))
# virus_lovers or final_destiny==D_PASS ==> PASS
# DISCARD (2xx) or REJECT (5xx) (depending on final_*_destiny)
# Equivalent flow diagram applies for spam checks.
# If a virus is detected, spam checking is skipped entirely.
# The following symbolic constants can be used in *destiny settings:
# D_PASS mail will pass to recipients, regardless of bad contents;
# D_DISCARD mail will not be delivered to its recipients, sender will NOT be
# notified. Effectively we lose mail (but will be quarantined
# unless disabled). Losing mail is not decent for a mailer,
# but might be desired.
# D_BOUNCE mail will not be delivered to its recipients, a non-delivery
# notification (bounce) will be sent to the sender by amavisd-new;
# Exception: bounce (DSN) will not be sent if a virus name matches
# $viruses_that_fake_sender_re, or to messages from mailing lists
# (Precedence: bulk|list|junk);
# D_REJECT mail will not be delivered to its recipients, sender should
# preferably get a reject, e.g. SMTP permanent reject response
# (e.g. with milter), or non-delivery notification from MTA
# (e.g. Postfix). If this is not possible (e.g. different recipients
# have different tolerances to bad mail contents and not using LMTP)
# amavisd-new sends a bounce by itself (same as D_BOUNCE).
# Notes:
# D_REJECT and D_BOUNCE are similar, the difference is in who is responsible
# for informing the sender about non-delivery, and how informative
# the notification can be (amavisd-new knows more than MTA);
# With D_REJECT, MTA may reject original SMTP, or send DSN (delivery status
# notification, colloquially called 'bounce') - depending on MTA;
# Best suited for sendmail milter, especially for spam.
# With D_BOUNCE, amavisd-new (not MTA) sends DSN (can better explain the
# reason for mail non-delivery, but unable to reject the original
# SMTP session). Best suited to reporting viruses, and for Postfix
# and other dual-MTA setups, which can't reject original client SMTP
# session, as the mail has already been enqueued.
$final_virus_destiny = D_DISCARD; # (defaults to D_BOUNCE)
$final_banned_destiny = D_BOUNCE; # (defaults to D_BOUNCE)
$final_spam_destiny = D_PASS; # (defaults to D_REJECT)
$final_bad_header_destiny = D_PASS; # (defaults to D_PASS), D_BOUNCE suggested
# Alternatives to consider for spam:
# - use D_PASS if clients will do filtering based on inserted mail headers;
# - use D_DISCARD, if kill_level is set safely high;
# - use D_BOUNCE instead of D_REJECT if not using milter;
# D_BOUNCE is preferred for viruses, but consider:
# - use D_DISCARD to avoid bothering the rest of the network, it is hopeless
# to try to keep up with the viruses that faker the envelope sender anyway,
# and bouncing only increases the network cost of viruses for everyone
# - use D_PASS (or virus_lovers) and $warnvirussender=1 to deliver viruses;
# - use D_REJECT instead of D_BOUNCE if using milter and under heavy
# virus storm;
# Don't bother to set both D_DISCARD and $warn*sender=1, it will get mapped
# to D_BOUNCE.
# The separation of *_destiny values into D_BOUNCE, D_REJECT, D_DISCARD
# and D_PASS made settings $warnvirussender and $warnspamsender only still
# useful with D_PASS.
# The following $warn*sender settings are ONLY used when mail is
# actually passed to recipients ($final_*_destiny=D_PASS, or *_lovers*).
# Bounces or rejects produce non-delivery status notification anyway.
# Notify virus sender?
#$warnvirussender = 1; # (defaults to false (undef))
# Notify spam sender?
#$warnspamsender = 1; # (defaults to false (undef))
# Notify sender of banned files?
#$warnbannedsender = 1; # (defaults to false (undef))
# Notify sender of syntactically invalid header containing non-ASCII characters?
#$warnbadhsender = 1; # (defaults to false (undef))
# Notify virus (or banned files) RECIPIENT?
# (not very useful, but some policies demand it)
#$warnvirusrecip = 1; # (defaults to false (undef))
#$warnbannedrecip = 1; # (defaults to false (undef))
# Notify also non-local virus/banned recipients if $warn*recip is true?
# (including those not matching local_domains*)
#$warn_offsite = 1; # (defaults to false (undef), i.e. only notify locals)
# Treat envelope sender address as unreliable and don't send sender
# notification / bounces if name(s) of detected virus(es) match the list.
# Note that virus names are supplied by external virus scanner(s) and are
# not standardized, so virus names may need to be adjusted.
# See README.lookups for syntax.
$viruses_that_fake_sender_re = new_RE(
qr'nimda|hybris|klez|bugbear|yaha|braid|sobig|fizzer|palyh|peido|holar'i,
qr'tanatos|lentin|bridex|mimail|trojan\.dropper|dumaru|parite|spaces'i,
qr'dloader|galil|gibe|swen|netwatch|bics|sbrowse'i,
[qr'^(EICAR\.COM|Joke\.|Junk\.)'i => 0],
[qr'^(WM97|OF97|W95/CIH-|JS/Fort)'i => 0],
# [qr/.*/ => 1], # true by default?
# where to send ADMIN VIRUS NOTIFICATIONS (should be a fully qualified address)
# - the administrator address may be a simple fixed e-mail address (a scalar),
# or may depend on the SENDER address (e.g. its domain), in which case
# a ref to a hash table can be specified (specify lower-cased keys,
# dot is a catchall, see README.lookups).
# Empty or undef lookup disables virus admin notifications.
# $virus_admin = undef; # do not send virus admin notifications (default)
# $virus_admin = {'not.example.com' => '', '.' => 'virusalert@example.com'};
# $virus_admin = 'virus-admin@example.com';
$virus_admin = "postmaster\@mail.$mydomain";
# equivalent to $virus_admin, but for spam admin notifications:
# $spam_admin = "spamalert\@$mydomain";
# $spam_admin = undef; # do not send spam admin notifications (default)
# $spam_admin = {'not.example.com' => '', '.' => 'spamalert@example.com'};
#advanced example, using a hash lookup table:
#$virus_admin = {
# 'baduser@sub1.example.com' => 'HisBoss@sub1.example.com',
# '.sub1.example.com' => 'virusalert@sub1.example.com',
# '.sub2.example.com' => '', # don't send admin notifications
# 'a.sub3.example.com' => 'abuse@sub3.example.com',
# '.sub3.example.com' => 'virusalert@sub3.example.com',
# '.example.com' => 'noc@example.com', # catchall for our virus senders
# '.' => 'virusalert@hq.example.com', # catchall for the rest
# whom notification reports are sent from (ENVELOPE SENDER);
# may be a null reverse path, or a fully qualified address:
# (admin and recip sender addresses default to $mailfrom
# for compatibility, which in turn defaults to undef (empty) )
# If using strings in double quotes, don't forget to quote @, i.e. \@
#$mailfrom_notify_admin = "virusalert\@$mydomain";
#$mailfrom_notify_recip = "virusalert\@$mydomain";
#$mailfrom_notify_spamadmin = "spam.police\@$mydomain";
# 'From' HEADER FIELD for sender and admin notifications.
# This should be a replyable address, see rfc1894. Not to be confused
# with $mailfrom_notify_sender, which is the envelope return address
# and should be empty (null reverse path) according to rfc2821.
# The syntax of the 'From' header field is specified in rfc2822, section
# '3.4. Address Specification'. Note in particular that display-name must be
# a quoted-string if it contains any special characters like spaces and dots.
# $hdrfrom_notify_sender = "amavisd-new <postmaster\@$mydomain>";
# $hdrfrom_notify_sender = 'amavisd-new <postmaster@example.com>';
# $hdrfrom_notify_sender = '"Content-Filter Master" <postmaster@example.com>';
# (defaults to: "amavisd-new <postmaster\@$myhostname>")
# $hdrfrom_notify_admin = $mailfrom_notify_admin;
# (defaults to: $mailfrom_notify_admin)
# $hdrfrom_notify_spamadmin = $mailfrom_notify_spamadmin;
# (defaults to: $mailfrom_notify_spamadmin)
$hdrfrom_notify_sender = "amavisd-new <postmaster\@$myhostname>";
# whom quarantined messages appear to be sent from (envelope sender)
$mailfrom_to_quarantine = undef; # original sender if undef, or set explicitly
# (default is undef)
# Location to put infected mail into: (applies to 'local:' quarantine method)
# empty for not quarantining, may be a file (mailbox),
# or a directory (no trailing slash)
# (the default value is undef, meaning no quarantine)
$QUARANTINEDIR = '/var/lib/amavis/virusmails';
#$virus_quarantine_method = "local:virus-%i-%n"; # default
#$spam_quarantine_method = "local:spam-%b-%i-%n"; # default
#use the new 'bsmtp:' method as an alternative to the default 'local:'
#$virus_quarantine_method = "bsmtp:$QUARANTINEDIR/virus-%i-%n.bsmtp";
#$spam_quarantine_method = "bsmtp:$QUARANTINEDIR/spam-%b-%i-%n.bsmtp";
# When using the 'local:' quarantine method (default), the following applies:
# A finer control of quarantining is available through variable
# $virus_quarantine_to/$spam_quarantine_to. It may be a simple scalar string,
# or a ref to a hash lookup table, or a regexp lookup table object,
# which makes possible to set up per-recipient quarantine addresses.
# The value of scalar $virus_quarantine_to/$spam_quarantine_to (or a
# per-recipient lookup result from the hash table %$virus_quarantine_to)
# is/are interpreted as follows:
# VARIANT 1:
# empty or undef disables quarantine;
# VARIANT 2:
# a string NOT containing an '@';
# amavisd will behave as a local delivery agent (LDA) and will quarantine
# viruses to local files according to hash %local_delivery_aliases (pseudo
# aliases map) - see subroutine mail_to_local_mailbox() for details.
# Some of the predefined aliases are 'virus-quarantine' and 'spam-quarantine'.
# Setting $virus_quarantine_to ($spam_quarantine_to) to this string will:
# * if $QUARANTINEDIR is a directory, each quarantined virus will go
# to a separate file in the $QUARANTINEDIR directory (traditional
# amavis style, similar to maildir mailbox format);
# * otherwise $QUARANTINEDIR is treated as a file name of a Unix-style
# mailbox. All quarantined messages will be appended to this file.
# Amavisd child process must obtain an exclusive lock on the file during
# delivery, so this may be less efficient than using individual files
# or forwarding to MTA, and it may not work across NFS or other non-local
# file systems (but may be handy for pickup of quarantined files via IMAP
# for example);
# VARIANT 3:
# any email address (must contain '@').
# The e-mail messages to be quarantined will be handed to MTA
# for delivery to the specified address. If a recipient address local to MTA
# is desired, you may leave the domain part empty, e.g. 'infected@', but the
# '@' character must nevertheless be included to distinguish it from variant 2.
# This method enables more refined delivery control made available by MTA
# (e.g. its aliases file, other local delivery agents, dealing with
# privileges and file locking when delivering to user's mailbox, nonlocal
# delivery and forwarding, fan-out lists). Make sure the mail-to-be-quarantined
# will not be handed back to amavisd for checking, as this will cause a loop
# (hopefully broken at some stage)! If this can be assured, notifications
# will benefit too from not being unnecessarily virus-scanned.
# By default this is safe to do with Postfix and Exim v4 and dual-sendmail
# setup, but probably not safe with sendmail milter interface without
# precaution.
$virus_quarantine_to = 'virus-quarantine'; # traditional local quarantine
#$virus_quarantine_to = 'infected@'; # forward to MTA for delivery
#$virus_quarantine_to = "virus-quarantine\@$mydomain"; # similar
#$virus_quarantine_to = 'virus-quarantine@example.com'; # similar
#$virus_quarantine_to = undef; # no quarantine
#$virus_quarantine_to = new_RE( # per-recip multiple quarantines
# [qr'^user@example\.com$'i => 'infected@'],
# [qr'^(.*)@example\.com$'i => 'virus-${1}@example.com'],
# [qr'^(.*)(@[^@])?$'i => 'virus-${1}${2}'],
# [qr/.*/ => 'virus-quarantine'] );
# similar for spam
#$spam_quarantine_to = 'spam-quarantine';
#$spam_quarantine_to = "spam-quarantine\@$mydomain";
#$spam_quarantine_to = new_RE( # per-recip multiple quarantines
# [qr'^(.*)@example\.com$'i => 'spam-${1}@example.com'],
# [qr/.*/ => 'spam-quarantine'] );
$spam_quarantine_to = undef;
# In addition to per-recip quarantine, a by-sender lookup is possible. It is
# similar to $spam_quarantine_to, but the lookup key is the sender address:
#$spam_quarantine_bysender_to = undef; # dflt: no by-sender spam quarantine
# Add X-Virus-Scanned header field to mail?
$X_HEADER_TAG = 'X-Virus-Scanned'; # (default: undef)
# Leave empty to add no header # (default: undef)
$X_HEADER_LINE = "by $myversion (Debian) at $mydomain";
$remove_existing_x_scanned_headers = 0; # leave existing X-Virus-Scanned alone
#$remove_existing_x_scanned_headers= 1; # remove existing headers
#$remove_existing_spam_headers = 0; # leave existing X-Spam* headers alone
$remove_existing_spam_headers = 0; # remove existing spam headers if
# spam scanning is enabled (default)
# set $bypass_decode_parts to true if you only do spam scanning, or if you
# have a good virus scanner that can deal with compression and recursively
# unpacking archives by itself, and save amavisd the trouble.
# Disabling decoding also causes banned_files checking to only see
# MIME names and MIME content types, not the content classification types
# as provided by the file(1) utility.
# It is a double-edged sword, make sure you know what you are doing!
#$bypass_decode_parts = 1; # (defaults to false)
# don't trust this file type or corresponding unpacker for this file type,
# keep both the original and the unpacked file for a virus checker to see
# (lookup key is what file(1) utility returned):
$keep_decoded_original_re = new_RE(
qr'^(ASCII(?! cpio)|text|uuencoded|xxencoded|binhex)'i,
# Checking for banned MIME types and names. If any mail part matches,
# the whole mail is rejected, much like the way viruses are handled.
# A list in object $banned_filename_re can be defined to provide a list
# of Perl regular expressions to be matched against each part's:
# * Content-Type value (both declared and effective mime-type),
# including the possible security risk content types
# message/partial and message/external-body, as specified by rfc2046;
# * declared (i.e. recommended) file names as specified by MIME subfields
# Content-Disposition.filename and Content-Type.name, both in their
# raw (encoded) form and in rfc2047-decoded form if applicable;
# * file content type as guessed by 'file' utility, both the raw
# result from 'file', as well as short type name, classified
# into names such as .asc, .txt, .html, .doc, .jpg, .pdf,
# .zip, .exe, ... - see subroutine determine_file_types().
# This step is done only if $bypass_decode_parts is not true.
# * leave $banned_filename_re undefined to disable these checks
# (giving an empty list to new_RE() will also always return false)
$banned_filename_re = new_RE(
qr'\.[a-zA-Z][a-zA-Z0-9]{0,3}\.(vbs|pif|scr|bat|com|exe|dll)$'i, # double extension
qr'.\.(exe|vbs|pif|scr|bat|com)$'i, # banned extension - basic
# qr'.\.(ade|adp|bas|bat|chm|cmd|com|cpl|crt|exe|hlp|hta|inf|ins|isp|js|
# jse|lnk|mdb|mde|msc|msi|msp|mst|pcd|pif|reg|scr|sct|shs|shb|vb|
# vbe|vbs|wsc|wsf|wsh)$'ix, # banned extension - long
# qr'^\.(exe|zip|lha|tnef)$'i, # banned file(1) types
# qr'^application/x-msdownload$'i, # banned MIME types
qr'^message/partial$'i, qr'^message/external-body$'i, # rfc2046
# See http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262631
# and http://www.cknow.com/vtutor/vtextensions.htm
# A little trick: a pattern qr'\.exe$' matches both a short type name '.exe',
# as well as any file name which happens to end with .exe. If only matching
# a file name is desired, but not the short name, a pattern qr'.\.exe$'i
# or similar may be used, which requires that at least one character precedes
# the '.exe', and so it will never match short file types, which always start
# with a dot.
# %virus_lovers, @virus_lovers_acl and $virus_lovers_re lookup tables:
# (these should be considered policy options, they do not disable checks,
# see bypass*checks for that!)
# Exclude certain RECIPIENTS from virus filtering by adding their lower-cased
# envelope e-mail address (or domain only) to the hash %virus_lovers, or to
# the access list @virus_lovers_acl - see README.lookups and examples.
# Make sure the appropriate form (e.g. external/internal) of address
# is used in case of virtual domains, or when mapping external to internal
# addresses, etc. - this is MTA-specific.
# Notifications would still be generated however (see the overall
# picture above), and infected mail (if passed) gets additional header:
# X-AMaViS-Alert: INFECTED, message contains virus: ...
# (header not inserted with milter interface!)
# NOTE (milter interface only): in case of multiple recipients,
# it is only possible to drop or accept the message in its entirety - for all
# recipients. If all of them are virus lovers, we'll accept mail, but if
# at least one recipient is not a virus lover, we'll discard the message.
# %bypass_virus_checks, @bypass_virus_checks_acl and $bypass_virus_checks_re
# lookup tables:
# (this is mainly a time-saving option, unlike virus_lovers* !)
# Similar in concept to %virus_lovers, a hash %bypass_virus_checks,
# access list @bypass_virus_checks_acl and regexp list $bypass_virus_checks_re
# are used to skip entirely the decoding, unpacking and virus checking,
# but only if ALL recipients match the lookup.
# %bypass_virus_checks/@bypass_virus_checks_acl/$bypass_virus_checks_re
# do NOT GUARANTEE the message will NOT be checked for viruses - this may
# still happen when there is more than one recipient for a message, and
# not all of them match these lookup tables. To guarantee virus delivery,
# a recipient must also match %virus_lovers/@virus_lovers_acl lookups
# (but see milter limitations above),
# NOTE: it would not be clever to base virus checks on SENDER address,
# since there are no guarantees that it is genuine. Many viruses
# and spam messages fake sender address. To achieve selective filtering
# based on the source of the mail (e.g. IP address, MTA port number, ...),
# use mechanisms provided by MTA if available.
# Similar to lookup tables controlling virus checking, there exist
# spam scanning, banned names/types, and headers_checks control counterparts:
# %spam_lovers, @spam_lovers_acl, $spam_lovers_re
# %banned_files_lovers, @banned_files_lovers_acl, $banned_files_lovers_re
# %bad_header_lovers, @bad_header_lovers_acl, $bad_header_lovers_re
# and:
# %bypass_spam_checks/@bypass_spam_checks_acl/$bypass_spam_checks_re
# %bypass_banned_checks/@bypass_banned_checks_acl/$bypass_banned_checks_re
# %bypass_header_checks/@bypass_header_checks_acl/$bypass_header_checks_re
# See README.lookups for details about the syntax.
# The following example disables spam checking altogether,
# since it matches any recipient e-mail address (any address
# is a subdomain of the top-level root DNS domain):
# @bypass_header_checks_acl = qw( user@example.com );
# @bad_header_lovers_acl = qw( user@example.com );
# See README.lookups for further detail, and examples below.
# $virus_lovers{lc("postmaster\@$mydomain")} = 1;
# $virus_lovers{lc('postmaster@example.com')} = 1;
# $virus_lovers{lc('abuse@example.com')} = 1;
# $virus_lovers{lc('some.user@')} = 1; # this recipient, regardless of domain
# $virus_lovers{lc('boss@example.com')} = 0; # never, even if domain matches
# $virus_lovers{lc('example.com')} = 1; # this domain, but not its subdomains
# $virus_lovers{lc('.example.com')}= 1; # this domain, including its subdomains
#or:
# @virus_lovers_acl = qw( me@lab.xxx.com !lab.xxx.com .xxx.com yyy.org );
# $bypass_virus_checks{lc('some.user2@butnot.example.com')} = 1;
# @bypass_virus_checks_acl = qw( some.ddd !butnot.example.com .example.com );
# @virus_lovers_acl = qw( postmaster@example.com );
# $virus_lovers_re = new_RE( qr'^(helpdesk|postmaster)@example\.com$'i );
# $spam_lovers{lc("postmaster\@$mydomain")} = 1;
# $spam_lovers{lc('postmaster@example.com')} = 1;
# $spam_lovers{lc('abuse@example.com')} = 1;
# @spam_lovers_acl = qw( !.example.com );
# $spam_lovers_re = new_RE( qr'^user@example\.com$'i );
# don't run spam check for these RECIPIENT domains:
# @bypass_spam_checks_acl = qw( d1.com .d2.com a.d3.com );
# or the other way around (bypass check for all BUT these):
# @bypass_spam_checks_acl = qw( !d1.com !.d2.com !a.d3.com . );
# a practical application: don't check outgoing mail for spam:
# @bypass_spam_checks_acl = ( "!.$mydomain", "." );
# (a downside of which is that such mail will not count as ham in SA bayes db)
# Where to find SQL server(s) and database to support SQL lookups?
# A list of triples: (dsn,user,passw). (dsn = data source name)
# More than one entry may be specified for multiple (backup) SQL servers.
# See 'man DBI', 'man DBD::mysql', 'man DBD::Pg', ... for details.
# When chroot-ed, accessing SQL server over inet socket may be more convenient.
# @lookup_sql_dsn =
# ( ['DBI:mysql:database=mail;host=127.0.0.1;port=3306', 'user1', 'passwd1'],
# ['DBI:mysql:database=mail;host=host2', 'username2', 'password2'] );
# ('mail' in the example is the database name, choose what you like)
# With PostgreSQL the dsn (first element of the triple) may look like:
# 'DBI:Pg:host=host1;dbname=mail'
# The SQL select clause to fetch per-recipient policy settings.
# The %k will be replaced by a comma-separated list of query addresses
# (e.g. full address, domain only, catchall). Use ORDER, if there
# is a chance that multiple records will match - the first match wins.
# If field names are not unique (e.g. 'id'), the later field overwrites the
# earlier in a hash returned by lookup, which is why we use '*,users.id'.
# $sql_select_policy = 'SELECT *,users.id FROM users,policy'.
# ' WHERE (users.policy_id=policy.id) AND (users.email IN (%k))'.
# ' ORDER BY users.priority DESC';
# The SQL select clause to check sender in per-recipient whitelist/blacklist
# The first SELECT argument '?' will be users.id from recipient SQL lookup,
# the %k will be sender addresses (e.g. full address, domain only, catchall).
# $sql_select_white_black_list = 'SELECT wb FROM wblist,mailaddr'.
# ' WHERE (wblist.rid=?) AND (wblist.sid=mailaddr.id)'.
# ' AND (mailaddr.email IN (%k))'.
# ' ORDER BY mailaddr.priority DESC';
$sql_select_white_black_list = undef; # undef disables SQL white/blacklisting
# If you decide to pass viruses (or spam) to certain recipients using the
# above lookup tables or using $final_virus_destiny=D_PASS, you can set
# the variable $addr_extension_virus ($addr_extension_spam) to some
# string, and the recipient address will have this string appended
# as an address extension to the local-part of the address. This extension
# can be used by final local delivery agent to place such mail in different
# folders. Leave these two variables undefined or empty strings to prevent
# appending address extensions. Setting has no effect on recipient which will
# not be receiving viruses/spam. Recipients who do not match lookup tables
# local_domains* are not affected.
# LDAs usually default to stripping away address extension if no special
# handling is specified, so having this option enabled normally does no harm,
# provided the $recipients_delimiter matches the setting on the final
# MTA's LDA.
# $addr_extension_virus = 'virus'; # (default is undef, same as empty)
# $addr_extension_spam = 'spam'; # (default is undef, same as empty)
# $addr_extension_banned = 'banned'; # (default is undef, same as empty)
# Delimiter between local part of the recipient address and address extension
# (which can optionally be added, see variables $addr_extension_virus and
# $addr_extension_spam). E.g. recipient address <user@example.com> gets changed
# to <user+virus@example.com>.
# Delimiter should match equivalent (final) MTA delimiter setting.
# (e.g. for Postfix add 'recipient_delimiter = +' to main.cf)
# Setting it to an empty string or to undef disables this feature
# regardless of $addr_extension_virus and $addr_extension_spam settings.
$recipient_delimiter = '+'; # (default is '+')
# true: replace extension; false: append extension
$replace_existing_extension = 1; # (default is false)
# Affects matching of localpart of e-mail addresses (left of '@')
# in lookups: true = case sensitive, false = case insensitive
$localpart_is_case_sensitive = 0; # (default is false)
# ENVELOPE SENDER WHITELISTING / BLACKLISTING - GLOBAL (RECIPIENT-INDEPENDENT)
# (affects spam checking only, has no effect on virus and other checks)
# WHITELISTING: use ENVELOPE SENDER lookups to ENSURE DELIVERY from whitelisted
# senders even if the message is recognized as spam. Effectively, for the
# specified senders, message RECIPIENTS temporarily become 'spam_lovers', with
# further processing being the same as otherwise specified for spam lovers.
# It does not turn off inserting spam-related headers, if they are enabled.
# BLACKLISTING: messages from specified SENDERS are DECLARED SPAM.
# Effectively, for messages from blacklisted senders, spam level
# is artificially pushed high, and the normal spam processing applies,
# resulting in 'X-Spam-Flag: YES', high 'X-Spam-Level' bar and other usual
# reactions to spam, including possible rejection. If the message nevertheless
# still passes (e.g. for spam loving recipients), it is tagged as BLACKLISTED
# in the 'X-Spam-Status' header field, but the reported spam value and
# set of tests in this report header field (if available from SpamAssassin,
# which may have not been called) is not adjusted.
# A sender may be both white- and blacklisted at the same time,
# settings are independent. For example, being both white- and blacklisted,
# message is delivered to recipients, but is tagged as spam.
# If ALL recipients of the message either white- or blacklist the sender,
# spam scanning (calling the SpamAssassin) is bypassed, saving on time.
# The following variables (lookup tables) are available, with the semantics
# and syntax as specified in README.lookups:
# %whitelist_sender, @whitelist_sender_acl, $whitelist_sender_re
# %blacklist_sender, @blacklist_sender_acl, $blacklist_sender_re
# SOME EXAMPLES:
#ACL:
# @whitelist_sender_acl = qw( .example.com );
# @whitelist_sender_acl = ( ".$mydomain" ); # $mydomain and its subdomains
# NOTE: This is not a reliable way of turning off spam checks for
# locally-originating mail, as sender address can easily be faked.
# To reliably avoid spam-scanning outgoing mail,
# use @bypass_spam_checks_acl .
#RE:
# $whitelist_sender_re = new_RE(
# qr'^postmaster@.*\bexample\.com$'i,
# qr'owner-[^@]*@'i, qr'-request@'i,
# qr'\.example\.com$'i );
$blacklist_sender_re = new_RE(
qr'^(bulkmail|offers|cheapbenefits|earnmoney|foryou|greatcasino)@'i,
qr'^(investments|lose_weight_today|market.alert|money2you|MyGreenCard)@'i,
qr'^(new\.tld\.registry|opt-out|opt-in|optin|saveonl|smoking2002k)@'i,
qr'^(specialoffer|specialoffers|stockalert|stopsnoring|wantsome)@'i,
qr'^(workathome|yesitsfree|your_friend|greatoffers)@'i,
qr'^(inkjetplanet|marketopt|MakeMoney)\d*@'i,
#HASH lookup variant:
# NOTE: Perl operator qw splits its argument string by whitespace
# and produces a list. This means that addresses can not contain
# whitespace, and there is no provision for comments within the string.
# You can use the normal Perl list syntax if you have special requirements,
# e.g. map {...} ('one user@bla', '.second.com'), or use read_hash to read
# addresses from a file.
# a hash lookup table can be read from a file,
# one address per line, comments and empty lines are permitted:
# read_hash(\%whitelist_sender, '/var/amavis/whitelist_sender');
# ... or set directly:
map { $whitelist_sender{lc($_)}=1 } (qw(
cert-advisory-owner@cert.org
owner-alert@iss.net
slashdot@slashdot.org
bugtraq@securityfocus.com
NTBUGTRAQ@LISTSERV.NTBUGTRAQ.COM
security-alerts@linuxsecurity.com
amavis-user-admin@lists.sourceforge.net
razor-users-admin@lists.sourceforge.net
notification-return@lists.sophos.com
mailman-announce-admin@python.org
zope-announce-admin@zope.org
owner-postfix-users@postfix.org
owner-postfix-announce@postfix.org
owner-sendmail-announce@Lists.Sendmail.ORG
owner-technews@postel.ACM.ORG
lvs-users-admin@LinuxVirtualServer.org
ietf-123-owner@loki.ietf.org
cvs-commits-list-admin@gnome.org
rt-users-admin@lists.fsck.com
owner-announce@mnogosearch.org
owner-hackers@ntp.org
owner-bugs@ntp.org
clp-request@comp.nus.edu.sg
surveys-errors@lists.nua.ie
emailNews@genomeweb.com
owner-textbreakingnews@CNNIMAIL12.CNN.COM
spamassassin-talk-admin@lists.sourceforge.net
yahoo-dev-null@yahoo-inc.com
# ENVELOPE SENDER WHITELISTING / BLACKLISTING - PER-RECIPIENT
# The same semantics as for global white/blacklisting applies, but this
# time each recipient (or its domain, or subdomain, ...) can be given
# an individual lookup table for matching senders. The per-recipient lookups
# override the global lookups, which serve as a fallback default.
# Specify a two-level lookup table: the key for the outer table is recipient,
# and the result should be an inner lookup table (hash or ACL or RE),
# where the key used will be the sender.
#$per_recip_blacklist_sender_lookup_tables = {
# 'user1@my.example.com'=>new_RE(qr'^(inkjetplanet|marketopt|MakeMoney)\d*@'i),
# 'user2@my.example.com'=>[qw( spammer@d1.example,org .d2.example,org )],
#$per_recip_whitelist_sender_lookup_tables = {
# 'user@my.example.com' => [qw( friend@example.org .other.example.org )],
# '.my1.example.com' => [qw( !foe.other.example,org .other.example,org )],
# '.my2.example.com' => read_hash('/var/amavis/my2-wl.dat'),
# 'abuse@' => { 'postmaster@'=>1,
# 'cert-advisory-owner@cert.org'=>1, 'owner-alert@iss.net'=>1 },
# Sanity limit to the number of allowed recipients per SMTP transaction
# $smtpd_recipient_limit = 1000; # (default is 1000)
# Resource limits to protect unpackers, decompressors and virus scanners
# against mail bombs (e.g. 42.zip)
# Maximum recursion level for extraction/decoding (0 or undef disables limit)
$MAXLEVELS = 14; # (default is undef, no limit)
# Maximum number of extracted files (0 or undef disables the limit)
$MAXFILES = 1500; # (default is undef, no limit)
# For the cumulative total of all decoded mail parts we set max storage size
# to defend against mail bombs. Even though parts may be deleted (replaced
# by decoded text) during decoding, the size they occupied is _not_ returned
# to the quota pool.
# Parameters to storage quota formula for unpacking/decoding/decompressing
# Formula:
# quota = max($MIN_EXPANSION_QUOTA,
# $mail_size*$MIN_EXPANSION_FACTOR,
# min($MAX_EXPANSION_QUOTA, $mail_size*$MAX_EXPANSION_FACTOR))
# In plain words (later condition overrules previous ones):
# allow MAX_EXPANSION_FACTOR times initial mail size,
# but not more than MAX_EXPANSION_QUOTA,
# but not less than MIN_EXPANSION_FACTOR times initial mail size,
# but never less than MIN_EXPANSION_QUOTA
$MIN_EXPANSION_QUOTA = 100*1024; # bytes (default undef, not enforced)
$MAX_EXPANSION_QUOTA = 300*1024*1024; # bytes (default undef, not enforced)
$MIN_EXPANSION_FACTOR = 5; # times original mail size (must be specified)
$MAX_EXPANSION_FACTOR = 500; # times original mail size (must be specified)
# Specify a path string, which is a colon-separated string of directories
# (no trailing slashes!) to be assigned to the environment variable PATH
# and to serve for locating external programs below.
# NOTE: if $daemon_chroot_dir is nonempty, the directories will be
# relative to the chroot directory specified;
$path = '/usr/local/sbin:/usr/local/bin:/usr/sbin:/sbin:/usr/bin:/bin';
# Specify one string or a search list of strings (first match wins).
# The string (or: each string in a list) may be an absolute path,
# or just a program name, to be located via $path;
# Empty string or undef (=default) disables the use of that external program.
# Optionally command arguments may be specified - only the first substring
# up to the whitespace is used for file searching.
$file = 'file'; # file(1) utility; use 3.41 or later to avoid vulnerability
$gzip = 'gzip';
$bzip2 = 'bzip2';
$lzop = 'lzop';
$uncompress = ['uncompress', 'gzip -d', 'zcat'];
$unfreeze = ['unfreeze', 'freeze -d', 'melt', 'fcat'];
$arc = ['nomarch', 'arc'];
$unarj = ['arj', 'unarj']; # both can extract, same options
$unrar = ['rar', 'unrar']; # both can extract, same options
$zoo = 'zoo';
$lha = 'lha';
$cpio = 'cpio'; # comment out if cpio does not support GNU options
# SpamAssassin settings
# Timout for SpamAssassin. This is only used if spamassassin does NOT
# override it (which it often does if sa_local_tests_only is not true)
$sa_timeout = 300; # default is 120 seconds
# $sa_local_tests_only = 1; # defaults to false
# AWL (auto whitelisting), requires spamassassin 2.44 or better
# $sa_auto_whitelist = 1; # defaults to undef
$sa_mail_body_size_limit = 5000*1024; # don't waste time on SA is mail is larger
# (less than 1% of spam is > 64k)
# default: undef, no limitations
# default values, can be overridden by more specific lookups, e.g. SQL
$sa_tag_level_deflt = -1000; # add spam info headers if at, or above that level
$sa_tag2_level_deflt = 0.0; # add 'spam detected' headers at that level
$sa_kill_level_deflt = $sa_tag2_level_deflt; # triggers spam evasive actions
# at or above that level: bounce/reject/drop,
# quarantine, and adding mail address extension
# The $sa_tag_level_deflt, $sa_tag2_level_deflt and $sa_kill_level_deflt
# may also be hashrefs to hash lookup tables, to make static per-recipient
# settings possible without having to resort to SQL or LDAP lookups.
# a quick reference:
# tag_level controls adding the X-Spam-Status and X-Spam-Level headers,
# tag2_level controls adding 'X-Spam-Flag: YES', and editing Subject,
# kill_level controls 'evasive actions' (reject, quarantine, extensions);
# it only makes sense to maintain the relationship:
# tag_level <= tag2_level <= kill_level
# string to prepend to Subject header field when message exceeds tag2 level
$sa_spam_subject_tag = '***SPAM*** '; # (defaults to undef, disables)
# (only seen when spam is not to be rejected
# and recipient is in local_domains*)
$sa_spam_modifies_subj = 1; # may be a ref to a lookup table, default is true
# Example: modify Subject for all local recipients except user@example.com
#$sa_spam_modifies_subj = [qw( !user@example.com . )];
# don't add ***UNCHECKED*** to the subject
$undecipherable_subject_tag = undef;
# @av_scanners is a list of n-tuples, where fields semantics is:
# 1. av scanner plain name, to be used in log and reports;
# 2. scanner program name; this string will be submitted to subroutine
# find_external_programs(), which will try to find the full program
# path name; if program is not found, this scanner is disabled.
# Besides a simple string (full program path name or just the basename
# to be looked for in PATH), this may be an array ref of alternative
# program names or full paths - the first match in the list will be used;
# As a special case for more complex scanners, this field may be
# a subroutine reference, and the whole n-tuple is passed to it as args.
# 3. command arguments to be given to the scanner program;
# a substring {} will be replaced by the directory name to be scanned,
# i.e. "$tempdir/parts", a "*" will be replaced by file names of parts;
# 4. an array ref of av scanner exit status values, or a regexp (to be
# matched against scanner output), indicating NO VIRUSES found;
# 5. an array ref of av scanner exit status values, or a regexp (to be
# matched against scanner output), indicating VIRUSES WERE FOUND;
# Note: the virus match prevails over a 'not found' match, so it is safe
# even if the no. 4. matches for viruses too;
# 6. a regexp (to be matched against scanner output), returning a list
# of virus names found.
# 7. and 8.: (optional) subroutines to be executed before and after scanner
# (e.g. to set environment or current directory);
# see examples for these at KasperskyLab AVP and Sophos sweep.
# NOTES:
# - NOT DEFINING @av_scanners (e.g. setting it to empty list, or deleting the
# whole assignment) TURNS OFF LOADING AND COMPILING OF THE ANTIVIRUS CODE
# (which can be handy if all you want to do is spam scanning);
# - the order matters: although _all_ available entries from the list are
# always tried regardless of their verdict, scanners are run in the order
# specified: the report from the first one detecting a virus will be used
# (providing virus names and scanner output); REARRANGE THE ORDER TO WILL;
# - it doesn't hurt to keep an unused command line scanner entry in the list
# if the program can not be found; the path search is only performed once
# during the program startup;
# COROLLARY: to disable a scanner that _does_ exist on your system,
# comment out its entry or use undef or '' as its program name/path
# (second parameter). An example where this is almost a must: disable
# Sophos 'sweep' if you have its daemonized version Sophie or SAVI-Perl
# (same for Trophie/vscan, and clamd/clamscan), or if another unrelated
# program happens to have a name matching one of the entries ('sweep'
# again comes to mind);
# - it DOES HURT to keep unwanted entries which use INTERNAL SUBROUTINES
# for interfacing (where the second parameter starts with \&).
# Keeping such entry and not having a corresponding virus scanner daemon
# causes an unnecessary connection attempt (which eventually times out,
# but it wastes precious time). For this reason the daemonized entries
# are commented in the distribution - just remove the '#' where needed.
@av_scanners = (
### http://clamav.elektrapro.com/
['Clam Antivirus-clamd',
\&ask_daemon, ["CONTSCAN {}\n", '/var/run/clamav/clamd.ctl'],
qr/\bOK$/, qr/\bFOUND$/,
qr/^.*?: (?!Infected Archive)(.*) FOUND$/ ],
@av_scanners_backup = (
# The most useful debugging tool is to run amavisd-new non-detached
# from a terminal window:
# amavisd debug
# Some more refined approaches:
# If sender matches ACL, turn debugging fully up, just for this one message
#@debug_sender_acl = ( "test-sender\@$mydomain" );
#@debug_sender_acl = qw( debug@example.com );
# May be useful along with @debug_sender_acl:
# Prevent all decoded originals being deleted (replaced by decoded part)
#$keep_decoded_original_re = new_RE( qr/.*/ );
# Turn on SpamAssassin debugging (output to STDERR, use with 'amavisd debug')
#$sa_debug = 1; # defaults to false
1; # insure a defined return
Übersehe ich etwas?
