My server didn’t boot after a power failure, even when I go back to a previous snapshot.
Ifoolow the following steps,
Hopefully one of you can provide me a suggestion, how I can solve this issue!
Thanks!
Thanks!
is this the whole output of your boot process?
Kind regards
Are you sure there is no hardware defect?
Sorry I forgot to close this post,
,Boot with verbose loglevel=8 debug=1 nosplash
as soon the boot process stoped, I run a fsck \dev\mapper/vg_ucs-root -y
reboot the system, and apply the noplash permanent by running ucr set grub/bootsplash=nosplash as root…
Thanks for the support!!
